How does curvature of an arch bridge affect its strength?
In summary, the relationship between the curvature of an arch bridge and its maximum load is based on vector diagrams of the forces acting on the bridge. Increasing the curvature decreases the length of the force vectors, resulting in less stress on the bridge. The stress is the magnitude of the force transmitted through the bridge's components, and the longer the force vector, the higher the stress. The calculation of the weight the bridge can carry depends on which component would fail first, which would require input from engineers.
maxf11
Hey, I've been looking into some civil/structural engineering for a school project, and came across bridge design. I've decided to try some integrating and optimising to do with an arch bridge (optimal cost/strength proportions). The math isn't too hard, but what I'm struggling with so far is finding any relationship between the curvature of the arch and the bridge's maximum load. I'm sure there must be one, there were some indicators of it in my research, but these were always very superficial. If anyone could point me in the right direction on this, I would be very grateful.
Here's one way to understand it. Draw a diagram of three consecutive blocks in the arch, and idealise them as point masses each with a fixed weight W, connected by stiff, massless rods.
The lower rod pushes up diagonally on the central point mass and the upper rod pushes down diagonally at a slightly shallower angle than that of the lower rod. The force in the lower rod will be larger than in the upper rod (the lower members bear the weight of all members above them).
Draw the vectors of the forces in the two rods end to end, in such a way that the head (arrow end) of the second vector (point A) is exactly above the tail of the first one (point B) (It doesn't matter which vector you draw first - the net result is the same). For the bridge to be stationary, the vector from A to B must be the weight of the central mass.
That vector AB is fixed, regardless of the curvature of the bridge - it's the weight of a standard block. Now, as you change the curvature, the two other sides of the vector triangle change. If you increase (decrease) the curvature they shorten (lengthen) because the angle opposite the AB vector increases (decreases). So you can see that increasing the curvature increases that angle and thus shortens the two force vectors, which means less stress in the bridge.
Given that framework, it's pretty easy to write some equations to quantify that.
Likes maxf11 and Simon Bridge
Thank you! That's very helpful, exactly what I was hoping for I'm not completely sure of how your diagram would work, if I'm not wrong there should be two rods connecting the three point masses, so what rods are you referring to with the lower and upper rods? And why would the upper rod push down at a slightly shallower angle than the lower one pushes up? I tried visualising it the way you suggested, but I feel like I'm not understanding it correctly as of yet.
Unfortunately I haven't taught myself to do diagrams on the web yet, so I'll use coordinates in the number plane instead.
Imagine the three point masses are at points U=(-2,1), V=(0,0) and W=(1,-2). The upper rod is UV and the lower is VW. The rods can only push in a direction that aligns with their length, so the lines of force of UV have gradient 0.5 and 2.0 respectively.
OK, I see where my thinking was off. Just to be sure I'm getting it right now, I've attached a screenshot of how I understand it: http://imgur.com/KHjEH4v. I also see how changing the curvature will affect the internal angle of the vector diagram, and the lengths of the vectors. Could you please explain how longer vectors mean more stress on the bridge? And how (if possible) I can calculate the amount of weight the bridge can carry based on this stress?
The stress is just another name for the magnitude of the force transmitted through its members - which in this case is the blocks. The length of a force vector is its magnitude. So the longer the force vector, the bigger the stress.
Calculating the weight it can carry will depend on what component would be the first to fail. Engineers would be the best placed to suggest that. Possibilities I can see are
(1) a block being crushed under the stress and disintegrating, thereby creating a gap and allowing the arch to collapse
(2) the foundation at either end being displaced by the stress, so that the arch flattens and collapses
(3) the stresses on either side of a block squeezing the block out of position
Each of these will depend on complex properties of the materials like compressibility and coefficients of friction, as well as the design of the foundations. Calculating the stress at various points in a bridge is much easier than estimating the load at which it will fail.
Suppose I focus on only one of them, and assume the construction in itself is perfect, that would essentially leave me only with the quoted option to investigate, right? If I choose a specific material, do you think I can calculate when this material will collapse under the stress?
Some more context: I'm doing all this in a mathematics-subject based investigation, so I'm fine with doing lots of calculations. In the end, what I intend to do is optimise cost (basically just amount of material used in the bridge) and 'strength' of the bridge, so this research is focussed mainly on finding equations for the stress in a bridge.
Could anyone else just briefly let me know if they have any insights whatsoever regarding this topic? It would be greatly appreciated, thanks.
There are basically two classes of arch bridge :
(1) The simple free standing inverted U shape bridge .
(2) The embedded arch bridge where the basic U shape is built into a larger masonry structure .
Stress analysis of a real arch bridge is quite complicated .
http://www.ikbrunel.org.uk/maidenhead-bridge
Thank you for all the responses, you have all been very helpful!
Related to How does curvature of an arch bridge affect its strength?
1. How does the curvature of an arch bridge affect its strength?
The curvature of an arch bridge plays a crucial role in determining its strength. The arch shape allows the weight of the bridge and the load it carries to be distributed evenly along the curve, which helps to prevent any weak points that could lead to collapse.
2. Does a higher arch mean a stronger bridge?
Not necessarily. While a higher arch may be visually impressive, it does not automatically make the bridge stronger. The strength of an arch bridge is determined by the type and quality of materials used, as well as the design and construction techniques used to build it.
3. Can the curvature of an arch bridge be adjusted to increase its strength?
Yes, the curvature of an arch bridge can be adjusted to increase its strength. By altering the height and width of the arch, engineers can optimize the distribution of weight and load along the bridge, making it more resistant to forces such as gravity and wind.
4. Are there any drawbacks to using a curved arch in bridge design?
While arch bridges are generally strong and durable, there are some potential drawbacks to using a curved arch. The construction process can be more complex and costly compared to other bridge designs, and the curved shape may limit the types of vehicles or loads that can safely cross the bridge.
5. How does the curvature of an arch bridge affect its ability to withstand natural disasters?
The curvature of an arch bridge can greatly affect its ability to withstand natural disasters such as earthquakes and strong winds. The curved shape allows the bridge to flex and distribute the forces of the disaster, rather than resisting them in a rigid manner. Additionally, the arch shape can help prevent the bridge from collapsing under its own weight during an earthquake.
  • STEM Academic Advising
26K
12K
  • General Engineering
