- #36
AlphaLearner
- 90
- 4
Finally came to a conclusion. There's nothing separate like an 'Insulator' and 'Dielectric'. Every insulator is dielectric. Every insulator has some degree of tolerance against electron flow no matter its state of matter is... That degree of tolerance is measured as volt/meter, Number of volts the current has between electrodes displaced by 1 meter. This even show smaller insulator requires some voltage to break through it and make current pass through it. The same insulator with larger length require much more larger voltage to pass through it . A cathode ray tube require over 10,000 volts to make electric current pass through gas over a few centimeters. But a lightning strike requires over 100 million volts to pass through a few meters of air. (Of course, gas in cathode ray tube is hydrogen and air is a mixture of gases so materials in both cases are different).
How could this be anywhere linked to resistivity in electron flow? Is it possible? Will a property like this even exist in conductors but of less/negligible value? Is this what the measure resistivity for them is?
