How does electron speed affect electric power?
In summary, the conversation discussed the relationship between the kinetic energy of individual electrons and the total electrical energy they create. The possibility of generating electric power using electrons with 1 MeV kinetic energy was also explored, with the suggestion of using a magnetohydrodynamic generator. However, it was concluded that this method is not practical compared to other alternatives.
Aakash Sunkari
TL;DR Summary
I have a beta emitter which produces electrons with around 1 MeV of kinetic energy, on average. If I were to use these electrons for electricity, how does the kinetic energy of the electron affect the electrical energy created by the movement of these electrons?
I've got a quick question on the relationship between the kinetic energy of individual electrons and the total electrical energy they create.
I have a radioisotope - a beta emitter - which produces electrons with around 1 MeV (1.60218×10-13 Joules / 4.45049×10-17 Watt-hours) of energy.
I keep researching the notion of electrical energy online, and I find that it is the result of either a.) electric potential or b.) kinetic energy. Furthermore, I also note that Electric Energy is related to two factors: the voltage and the current.
Given that 1 eV is equal to the amount of kinetic energy an electron gains when moved across a potential difference of one volt, am I correct to assume that since I am producing electrons with 4.45049×10-17 Watt-hours of kinetic energy, I will be able to obtain 4.45049×10-17 Watt-hours of electrical energy, assuming that this is a perfect system and no energy is lost due to heat?
Please correct me if any part of my understanding is wrong.
Thank you all in advance!
Likes Abdullah Almosalami
How can we generate electric power with electrons that have 1 MeV kinetic energy ? A blunt idea with low efficiency comes to my mind. Heat a target by bombard of the electrons and make it a heat source for electricity generation as fire and nuclear power plants.
EDIT: For power generation from heat source, thermoelectric conversion element is useful as it is in nuclear batteries.
anuttarasammyak said:
How can we generate electric power by electrons that have kinetic energy is 1 MeV ? A blunt idea of low efficiency comes to my mind. Heat a target by bombard of the electrons and make it a heat source for electricity generation as fire and nuclear power plants.
I wasn't thinking necessarily using the electrons for heat generation, but perhaps using the flow of the electrons as a "current" - since these electrons are already charged particles. So would this electric energy be equivalent to the kinetic energy these electrons possess?
Electrons moving in a wire mostly contain electrical potential (volts) energy. This is relatively easy to manipulate. A 1 MeV beta particle has already converted any potential into Kinetic Energy. The cat is out of the bag. Measuring its energy in electron volts makes it no easier to use it as a current source for electric power.
Likes Aakash Sunkari
Magnetohydrodynamic generator could be of your interest.
Likes hutchphd and Aakash Sunkari
Here is an article that covers that possibility.
https://arxiv.org/ftp/arxiv/papers/1511/1511.07427.pdf
Above found with:
https://www.google.com/search?&q=atomic+battery+seminar+pdf+download
Also try the search with just: atomic battery
Many years ago I got a contract to investigate small power sources with over 100 years of lifetime. Yes, the approach you are asking about was evaluated and came in at the absolute bottom of the list for terrestial use. There are just too many other power sources available. You can get a very high voltage from an atomic battery but the power density is really tiny.
Cheers,
Tom
p.s. The client eventually settled on a wind-up spring that a user could wind/rewind as needed. Their logic was if there was no one to wind it there was no sense in storing the energy.
Flawless!
Likes rbelli1
If you are talking about energy, then the 'eV' is not really an unit of measure in the right dimension. It is eV/piece. To get the energy right, first you need to get the amount of electrons right.
The amount of electrons in a given time is actually called 'current', what will depend on the amount of decays in your beta emitter over a given time.
All the energy will be lost as heat. There is no change in net charge within the material.
Since you specified "a perfect system and no energy is lost due to heat", then yes, I'm sure it could be done. For example decelerate the electron in an e-field and when it stops it will have only electric potential energy equal to the original kinetic energy.
Of course, as everyone has said, it's not very practical compared to other solutions.
Flawless!
That's a perfect example of why you need to understand the intent of the question not just the actual question asked. The intent may sometimes only be loosely related to series of words making up the question. Sometimes not at all.
BoB
  • Love
Likes Tom.G
From the thread's title "How does electron speed affect electric power?" makes me want to post this from http://hyperphysics.phy-astr.gsu.edu/hbase/electric/miccur.html
Although your light turns on very quickly when you flip the switch, and you find it impossible to flip off the light and get in bed before the room goes dark, the actual drift velocity of electrons through copper wires is very slow. It is the change or "signal" which propagates along wires at essentially the speed of light.
Related to How does electron speed affect electric power?
1. How does the speed of electrons affect electric power?
The speed of electrons does not directly affect electric power. Electric power is the rate at which energy is transferred, and it is determined by the voltage and current in a circuit. However, the speed of electrons does play a role in the efficiency of energy transfer.
2. Does increasing the speed of electrons increase electric power?
No, increasing the speed of electrons does not increase electric power. As mentioned before, electric power is determined by voltage and current, not the speed of electrons. In fact, increasing the speed of electrons can actually decrease the efficiency of energy transfer due to factors such as resistance and heat loss.
3. How does the speed of electrons affect the flow of electricity?
The speed of electrons does not affect the flow of electricity. Electric current is the flow of electrons through a circuit, and it is determined by the voltage and resistance in the circuit. The speed of electrons may vary, but the overall flow of electricity remains constant.
4. Can the speed of electrons be controlled to increase electric power?
No, the speed of electrons cannot be controlled to increase electric power. As mentioned before, electric power is determined by voltage and current, not the speed of electrons. The speed of electrons is a natural property and cannot be manipulated in this way.
5. How does the speed of electrons in a wire affect the brightness of a lightbulb?
The speed of electrons in a wire does not directly affect the brightness of a lightbulb. The brightness of a lightbulb is determined by the amount of energy that is transferred to the bulb, which is determined by the voltage and current in the circuit. However, a higher speed of electrons may result in more efficient energy transfer, leading to a brighter lightbulb.
  • Electrical Engineering
  • Quantum Physics
