How does flux density scale with redshift?
In summary, The flux density of a source at a certain redshift can be estimated by scaling the observed flux density at a different redshift using the formula: $$S \propto \frac{1}{(1+z)D_L^2}$$. This takes into account the effects of photon energy and time dilation, as well as the luminosity distance, which is defined as ##D_L = (1+z)^2 D_A##. The factor of ##1+z## in the formula is due to the redshift, and the factor of ##D_L^2## takes into account the increased distance to the source. The temperature of black body radiation in an expanding universe also plays a role in the scaling, as it affects the
givingup
I'm not sure I understand how to correctly scale flux density with redshift. That is, if I observe say 10 Jy at my observing frequency coming from a source at z = 0.3, how can I estimate the flux density I would expect from the same source at z=2? From what I understand, the final scaling is given by
$$S \propto \frac{1}{(1+z)}$$,
but I'm not sure I understand how that comes about. I believe there are two factors of 1/(1+z) due to the photon energy and time dilation, but I'm not sure what other factors to take into account, such that it reduces to only one factor of (1+z) in the denominator.
Furthermore, it seems strange to me that in the example I give, a 10 Jy source at z=0.3 is only dimmed to a flux density of 4.3 Jy at z=2. Doesn't this suggest that one could in principle see this source to very extreme redshifts (pending the sensitivity of the instrument, of course). Or have I made a mistake in the scaling?
Space news on Phys.org
That is only the scaling from redshift, the increased distance has to be taken into account as well to get the luminosity distance.
Otherwise all sources in our galaxy (including the Sun) would have the same brightness...
Ah of course, makes sense, thank you!
So the correct scaling should be:
Is that correct?
The luminosity distance takes redshift into account already.
Ok, I thought I might be double counting somewhere. So the flux is just inversely proportional to the square of the luminosity distance (makes sense!)? And the (1+z) factor is just from the luminosity distance.
Yes. The luminosity distance is defined as:
$$D_L = (1+z)^2 D_A$$
Here ##D_A## is known as the "angular diameter distance", which is the distance that we would measure from looking at the apparent size of the object (see here if you want the gory details, as distance in a curved space-time is a tricky concept). The factor of ##1+z## multiplies the distance because the redshift dims the light coming from the source. You might have expected the factor of ##1+z## to have a square root in front of it given your earlier posts, rather than squared. One way to understand this is to think about how the expansion impacts black body radiation. The temperature of black body radiation in an expanding universe is proportional to ##1/(1+z)##. This can be seen from looking just at the behavior of the peak of Planck's Law, which is directly proportional to temperature. But as the energy density of black body radiation scales as the fourth power of temperature, so does the flux. Thus the energy scaling of incoming radiation due to the expansion itself scales as ##1/(1+z)^4##. Hopefully that's clear.
The flux is then:
$$S = {L \over 4\pi D_L^2}$$
Here ##L## is the luminosity.
Likes mfb
This is not taking account for cosmological parameters
Related to How does flux density scale with redshift?
1. What is flux density?
Flux density is the amount of energy that passes through a unit area in a unit time. In astronomy, it is often used to measure the amount of light or other electromagnetic radiation received from a celestial object.
2. How does redshift affect flux density?
Redshift is a phenomenon that occurs when light waves are stretched as the source object moves away from the observer. This stretching causes a decrease in the observed flux density, as the same amount of energy is spread out over a larger area.
3. What is the relationship between flux density and redshift?
The relationship between flux density and redshift is inversely proportional. As redshift increases, flux density decreases, and vice versa.
4. Why does flux density decrease with increasing redshift?
This is due to the expansion of the universe. As objects move away from us, their light waves are stretched, resulting in a decrease in the observed flux density.
5. Can flux density be used to determine the redshift of an object?
Yes, flux density measurements can be used to determine the redshift of an object. By comparing the observed flux density to the expected flux density for a given object, scientists can calculate the redshift and therefore the distance of the object from Earth.
