How does Gauge fixing fix anything?
In summary, the Lorenz gauge is a partial gauge fixing, and the Coulomb gauge is not. However, the point of using the Lorentz condition is that it is relativistically covariant. Sometimes covariance is more important than uniqueness.
carllacan
274
I've looked everywhere and I haven't found an explanation of why is it useful to introduce gauge conditions. I've also searched in this forum, and none of the existing threads I've read answered my question. I apologize if there is and I have failed to find it.
My problem is that, as I see it, gauge fixing fixes nothing. We can still perform transformations that will not affect the field. Let me expose my reasoning:
The electromagnetic field potential is undefined up to the derivative of a function because if we transform Aμ like Aμ → A'μ = Aμ + ∂μ Λ the field is the same. In order to fix this we impose ∂μ A μ = 0.
Now A needs to satisfy this condition, and so does A', so we have
μ A' μ = 0
μ A μ + ∂μμ Λ = 0
μμ Λ = 0
and now we have restricted the kinds of Λ we can use for the gauge transformations, but we still haven't ruled out all of them, so we can impose Coulomb's conditions ∂i A i = 0 and A0 = 0.
Now A and A' need to satisfy these conditions, so we have
i A' i = 0
i A i + ∂ii Λ = 0
ii Λ = 0
So now we have two conditions on the functions Λ
ii Λ = 0
Λ0 = 0
and we have restricted the transforms we can do, but we haven't ruled out all of them, since we can still transform using a Λ that satisfies those conditions. Shouldn't the gauge fixing rule out every possible function Λ, so there is one and only one potential for every field?
I'm honestly not sure. I have never actually used the Coulomb gauge.
Oh, ok.
But, Coulomb gauge aside, is it not a problem that the Lorentz condition only fixes the problem partially? What is the point of using it then?
After a brief look it looks like the Coulomb gauge is not a partial gauge fixing, but I am not confident in that.
The point is that it is a relativistically covariant gauge condition. If it is satisfied in one frame then it is satisfied in all frames. The same is not true of the Coulomb gauge, which is why I never use it.
Many times covariance is more important than uniqueness.
No, not necessarily. There are many cases in which you are left with some remaining gauge degrees of freedom, like in General Relativity and String Theory. Like Dale says, it depends on what you want. Covariant gauge choices are nice because your calculations remain explicitly covariant. But your calculation shouldn't depend on your gauge choice.
If you are a bit familiar with string theory, one case in which this is clear is in analyzing the equations of motion. You can do this by imposing non-covariant gauge conditions (the so-called "static gauge"), but at the end of your analysis you have to check again that everything is still covariant (you have to check again if the spacetime coordinates satisfy the Lorentz algebra). And that is a very tedious calculation, I can tell you. This turns out to be the case only if (among other things) a certain amount of spacetime dimensions is assumed. In a covariant analysis you don't have to do this, and there the same amount of spacetime dimensions is again needed but for a different reason. Same result, but different calculations.
Fixing a gauge is similar to fixing a coordinate system in classical mechanics. Often, there you want to fix coordinates up to a Galilei transformation. This leaves you with the class of inertial observers. Only in particular calculations you want to uniquely fix the coordinates, such that you stick to one observer at one place at one instant in time.
Likes vanhees71
Related to How does Gauge fixing fix anything?
1. How does gauge fixing work?
Gauge fixing is a mathematical procedure used in the field of theoretical physics, particularly in quantum field theory, to remove the redundancy in the mathematical description of a physical system. This redundancy arises due to the presence of gauge symmetries, which are transformations that do not change the physical observables of the system. By fixing a gauge, we impose a constraint on the mathematical description of the system, making it more manageable and easier to work with.
2. What is the purpose of gauge fixing?
The purpose of gauge fixing is to simplify the mathematical description of a physical system by removing the gauge freedom. This allows us to more easily calculate physical observables and make predictions about the system. Gauge fixing is also important in the process of quantization, where we convert a classical theory into a quantum one.
3. How does gauge fixing affect the physical interpretation of a system?
Gauge fixing does not affect the physical interpretation of a system. It is simply a mathematical procedure that helps us to better understand and calculate physical quantities. The physical observables of a system remain unchanged, regardless of the gauge chosen.
4. Is gauge fixing always necessary?
No, gauge fixing is not always necessary. In some cases, it is possible to work with the gauge symmetry without fixing it. However, in many cases, gauge fixing is necessary to simplify the mathematical description of a system and make it more manageable.
5. Can gauge fixing be applied to any physical system?
Yes, gauge fixing can be applied to any physical system that exhibits gauge symmetries. In fact, it is a fundamental tool in theoretical physics and is used in a wide range of fields, including electromagnetism, quantum mechanics, and general relativity.
  • Classical Physics
  • Quantum Physics
  • Beyond the Standard Models
  • Classical Physics
