How Does General Relativity Predict an Expanding Universe
In summary: They're both solutions.What did Einstein think his equations predicted, did he think it would predict expansion, or contraction.In summary, the equations predict an expanding universe, without the need for a "Big Bang" to set it into motion. Radiation density is not significant in an expanding universe, and the role of radiation density is gradually decreasing over time.
Hello Everyone,
Back when Einstein was formulating General Relativity his equations just could not predict a static universe. I have read that they actually predicted an expanding Universe. Later Friedmann derived an equation from GR that would explain how an Expanding Universe would evolve. This was a very unpopular opinion at the time, I think they didn't even think there was more than one galaxy in the universe, this caused Einstein to add a Cosmological Constant such that it would result in a static universe. Now my understanding of General Relativity is quite elementary so I am curious as to these equations would predict an expanding universe without the need for some sort of 'Big Bang' to set the universe into motion
I am also curious as to the role of radiation density in an expanding universe.
Thanks in advance,
Space news on Phys.org
More precisely, they could not predict a static universe without a cosmological constant in them. Einstein's original derivation did not include one, but that was because his original derivation, as we now know, was actually not the most general one possible.
The original equations, without a cosmological constant, allow solutions that describe both and expanding and a contracting universe. There is nothing in the equations that privileges one over the other.
They don't. More precisely, they don't tell you what originally "set the universe into motion". They tell you that at some time in the past, the universe was very hot, very dense, and expanding very rapidly, and that since then, it has gotten much cooler, much less dense, and is expanding much more slowly. But they don't tell you what originally caused the early hot, dense, rapidly expanding state.
In the early universe, radiation density was very significant; it was actually larger than the density of matter, so the radiation density dominated the dynamics, i.e., it was the primary determiner of how the rate of expansion evolved. Over time, however, the radiation density decreased faster than the matter density, and so it gradually became negligible. Today it is several orders of magnitude smaller than the matter density and has no significant effect on the dynamics.
What did Einstein think his equations predicted, did he think it would predict expansion, or contraction. Would this impact which side of the equation Einstein would want to put a cosmological constant in?
When Einstein worked on GR, people thought that the universe was static. But without a cosmological constant, a current state of equilibrium will pass over into contraction. So I guess that without the cosmological constant, Einstein would have predicted contraction.
I do not understand your question.
As in Left Hand Side or Right Hand Side, a cosmological constant would supposedly have opposite effects based on which side of the equation you put the term on.
But in principle, you can move any constant from the lhs of an equation to the rhs by simple addition resp. subtraction. So the difference would merely be the sign of the constant. Thus, I still do not get the question.
Yeah that is true when you're rearranging an equation, but I'm referring to just randomly adding a term in. Like if you added a positive cosmological constant to one side it might have a repulsive effect, but on another side an attractive effect? Anyway I understand my question was a bit vague so sorry.
It predicts both. As I said in post #2, without a cosmological constant there are expanding solutions and contracting solutions, but no static solutions. AFAIK Einstein didn't really care which one, expanding or contracting; the main thing he cared about was that there were no static solutions. That was why he added the cosmological constant.
Yes. The solution with a positive cosmological constant on the LHS and zero on the RHS (i.e., no other stress-energy present) is called "de Sitter spacetime", and the solution with a negative cosmological constant on the LHS and zero on the RHS is called "anti-de Sitter spacetime". These are certainly different solutions.
In the Einstein static universe, there is a positive cosmological constant on the LHS of the field equation, and a nonzero stress-energy tensor describing ordinary matter and energy on the RHS, and the effects of the two balance in just the right way to make the solution as a whole static. There is no way to do this with a negative cosmological constant on the LHS.
Even with a cosmological constant, it's not possible to have a static (non-expanding) universe.
The problem is that the static universe solution with a cosmological constant is unstable: if there is any motion of matter, then some parts of the universe will get a little bit more or less dense than others. The more dense regions will collapse on themselves, while the less dense regions will expand forever. It's just not possible to have a universe which neither expands nor contracts.
Not in practical terms, yes, for the reason you give. But the idealized model still exists. AFAIK Einstein didn't realize the stability issue with the model when he proposed it; it was only realized later.
Related to How Does General Relativity Predict an Expanding Universe
1. How does general relativity explain the expansion of the universe?
General relativity predicts an expanding universe through the application of Einstein's field equations, which describe the relationship between matter, energy, and spacetime. These equations show that the curvature of spacetime is directly related to the distribution of matter and energy in the universe. As the universe expands, the matter and energy within it become more spread out, causing the curvature of spacetime to change, leading to the expansion of the universe.
2. What evidence supports general relativity's prediction of an expanding universe?
There are several pieces of evidence that support general relativity's prediction of an expanding universe. One of the key pieces of evidence is the observation of the redshift in the light from distant galaxies. This redshift is caused by the expansion of the universe, which stretches the wavelength of light as it travels through space. Additionally, the cosmic microwave background radiation, which is leftover radiation from the Big Bang, also supports the idea of an expanding universe.
3. Does general relativity accurately predict the rate of expansion of the universe?
There is ongoing research and debate about whether general relativity accurately predicts the rate of expansion of the universe. Currently, the most widely accepted model is the Lambda-CDM model, which combines general relativity with the concept of dark energy to explain the observed rate of expansion. However, there are still discrepancies and uncertainties in our understanding of the expansion rate, and further research and observations are needed to fully understand this phenomenon.
4. Can general relativity also explain the acceleration of the expansion of the universe?
General relativity alone cannot fully explain the accelerated expansion of the universe. This phenomenon is currently attributed to the presence of dark energy, a mysterious force that is thought to make up about 70% of the total energy in the universe. The exact nature of dark energy is still not fully understood, and it remains a subject of ongoing research and study.
5. What does the expanding universe mean for the future of the universe?
The current understanding is that the universe will continue to expand indefinitely. As the expansion continues, galaxies and other structures will become more and more spread out, and the universe will become colder and darker. This process is known as the "heat death" of the universe, and it is thought to be the eventual fate of our expanding universe.
  • Cosmology
  • Cosmology
