How does GPS correct for time dilation?
  • #51
A.T. said:
So you need a 3rd satellite to choose one of the two points,
PeterDonis said:
You do if you have no other knowledge at all about your position,
No, the knowledge about being at sea levels is already included there. If you do have a clock, two satellites will give you a solution circle, which intersects the surface at two points. So you need a 3rd satellite to choose one of the two surface points. That's 3 satellites for 2 variables (position on surface).
  • #52
mfb said:
Only if you rely on a clock in your receiver. Typical distance differences between two satellites are of the order of 10000km. If both satellite clocks are wrong in the same way, then the difference is only ##4 \times 10^{-10}## times the distance difference, a few millimeters. The incorrect data about the satellite position (because keeping track of the orbit will be wrong) is more relevant..
They are potentially more relevant, but they are still insignificant here: in 38 μs (the daily relativistic clock drift) a satellite moves by merely about 15 cm. In fact, as stated in the GPS documentation I referenced in post #26 already, the satellite clocks are allowed to drift up to 1 ms relatively to the ground clock before they are corrected. So even without a correction for the overall relativistic clock drift, the satellite positions would be off by only about 5 m in one month (before the clocks are corrected).
  • #53
PeterDonis said:
But suppose the GPS satellite clock rates were uncorrected (i.e., they all gained 38 us/day on ground clocks), and they got re-synchronized once a day. And suppose the re-synchronizations didn't all happen at the same time. Then you could be receiving signals from different satellites with up to 38 us difference in their offsets (in the worst case), because some had just been updated and some had gone a day without being updated yet.
This scenario may be what Ashby's statement was referring to; I'm not sure.
My understanding from the GPS documentation is that no two satellite clocks differ by more than 20 ns at any time.
  • #54
This makes some sense. But you're suggesting that the GPS satellites are out of sync with each other which no reference I've seen makes any mention of...anyway the document referenced by Fantasist looks quite legitimate and does say that the satellites are in sync to within 20ns Aaron
  • #55
Once again: only if you have no other prior knowledge about your position. But suppose the two surface points are 1000 km apart, and you know your approximate position to within 100 km. Then you don't need a third satellite to pick which surface point is the correct one; only one of them will be within the 100 km-wide approximate area you already know.
The key difference here is that, if you only have one satellite (in this idealized case), you have a continuous range of possible positions. A second satellite reduces the possibilities to a discrete set. Approximate knowledge of your position does not pick out a particular point from a continuous range--if you know your approximate position to within 100 km, knowing that it's also somewhere on a circle (the intersection of one satellite sphere with the surface of the Earth) does not pick out a single point; it only picks out the arc of the circle which is within the 100 km approximate range. But approximate knowledge can pick out a unique point from a discrete set: adding the second satellite, by eliminating all but two of the points on the whole circle that the first satellite gave you, eliminates all but one of the points on that circular arc (the other possible point is outside the 100-km area so it's not a possible solution given your prior knowledge).
  • #56
I'm suggesting no such thing. I'm saying that in the hypothetical situation where the GPS satellite clock rates were not corrected, and they were only re-synchronized with ground clocks once a day, there could be as much as 38 us difference between the offset of the clocks in two different satellites (more precisely, the bias of a given receiver's clock relative to the clocks on two different satellites could differ by as much as 38 us).
Of course this hypothetical situation is not the actual situation, because on the actual GPS satellites the clock rates are corrected to be the same as the rate of clocks on the geoid. (I said this explicitly in post #50.) But thinking about what would have happened in that hypothetical situation may help to explain why physicists say that the correction of the clock rates of the GPS satellites is in fact a critical feature in making sure position fixes are accurate.
  • #57
What I meant was that you are suggesting that the GPS satellites would be out of sync with each other without the offset. So far, I haven't seen any reference mentioning that the GPS satellites would be out of sync with each other, they all seem to talk about how they would be out of sync with the receiver clock.
Anyway I think you have a good point. I'll do a bit more reading to see if I can confirm your intuition.
BTW, just as an aside, I think that when the GPS clocks are periodically calibrated to a ground station, they should be able to calibrate not just their offset, but their rate too.regards,
Aaron
  • #58
Even in this hypothetical situation (it was not clear to me that you were considering this), you could avoid these errors - you could correct for it in satelitte software, or at least include data about the last synchronization event (so the receiver can correct for it).
  • #59
I agree with Peter: GPS clocks are calibrated to Earth based clocks because they are the clocks most relevant to a location on earth. If you were intent on locating a position on the moon, a moon based clock would be best. The target is distinct from the gun.
  • #60
I'm not sure that's possible with the current satellite design; AFAIK the clock rate correction is fixed when the satellite is built. However, I don't see any reason in principle why you couldn't design a satellite clock whose rate was adjustable.
  • #61
I am surprised that this thread has gone on for 3 pages. I'm afraid I haven't had the time to go through each and every response. I still have a remark that I hope will be helpful.
My $.02. It would indeed be possible, in theory, to not adjust the rate of the GPS clocks. For a reference, see "Precis of General Relativity" by Misner, http://arxiv.org/abs/gr-qc/9508043 (or http://arxiv.org/pdf/gr-qc/9508043v1.pdf for the pdf).
For GPS the measuring instruments can be taken to be either ideal SI atomic clocks in trajectories determined by known forces, or else electromagnetic signals describing the state of the clock that radiate the signal. Each clock maintains its own proper time (but may convert this via software into other information when it transmits).
I believe Misner's paper was written in response to Ashby's.
However, it at least appears CONVENIENT, though not NECESSARY, to have the clocks transmit a coordinate time rather than proper time, specifically the coordinate time called atomic time, also known as TAI time. I was curious, personally, as to which approach the European Union's "Galileo" positioning system used, but I wasn't able to find anything definite in the amount of time I had to dedicate to find what sort of time the Galileo satellites transmitted.
Having the clocks transmit their coordinate time, rather than their proper time, makes analysis via coordinates easier (as long as you've settled on a consistent coordinate choice), and hopefully easy to understand as well. But either approach will do.
It is of course not absolutely NECESSARY to use any particular coordinate system. Usually the position coordinates are desired in an ECEF coordinate system (Earth centered, Earth fixed) - because in this coordinate system, points on the rotating Earth have constant coordinates, which is what's generally meant by a "position" on the rotating Earth. Light rays do not follow straight lines in the ECEF coordinates, however, so the usual choice is use a different coordinate system, ECI (Earth Centered Inertal) coordinates for the bulk of the analysis, which makes analysis of the trajectories of the radio signals easy because the radio signals can be presumed to travel in straight lines in this coordinate system (with the possible exception of some minor atmospheric effects). Then one converts the results from ECI back to ECEF at the end of the analysis. The usual choice for the time coordinate system is known as atomic time aka TAI time, thus the time coordinate used by TAI are hopefully familiar to the reader (though all of the technical details may not be familiar). Note that civil time, UCT, aka Coordinated universal time, is derived from TAI time by the addition of leap seconds to keep UCT in synch with the sun / solar time. TAI time is equal to proper time for objects at rest on the surface of the Earth only at sea level (more technically, on the geoid), as several other posters have already noted.
I also rather strongly suspect that some of the non-science-advisor posters in this thread are clinging to the notion of absolute time, most likely without realizing it, and that this is the ultimate source of their confusion with regards to the issue of time dilation. Unfortunately, I'm not aware of any good strategy to clear up this sort of confusion :(.
If there is interest, and I have the time, I might try to write something up about the relationship between the relativity of simultaneity and time dilation, but experience has shown me that it seems a hard point to get across.
  • #62
pervect said:
objects at rest on the ground have constant ECI coordinates
Is this correct? I thought the ECI frame was a non-rotating frame centered on the Earth, so in this frame an object at rest on the rotating Earth is moving (unless it's at one of the poles). I believe the term for a frame that is fixed to the Earth is ECEF (Earth-centered Earth-fixed). Evidently this frame would be a non-inertial frame.
  • #63
Just a disclaimer, I don't know whether the satellite's clock rate is adjustable or not.
That said, I think its very likely. Almost all electronics circuits which require precise timing consist of a not-so-stable, but controllable clock which is phase-locked to a stable reference clock rate (such as a quartz crystal oscillator, but I guess in the case of GPS it is the atomic clock). Using this method (its called a phase-locked-loop), you can get more or less any clock rate you want (that's an exaggeration so don't quote me), and its controllable.
If you already knew all that then pls ignore...regards,
Aaron
  • #64
Good catch - bad post - with luck I can fix it still.
  • #65
The issues addressed in this thread have as such little to do with Relativity. It is merely about how drifts of the satellite clocks (due to whatever causes) affect the GPS operations and what can and is being done to correct for these drifts. It is just a technical question, not a scientific one.
  • #66
That is what it has turned into. It wasn't my original question.Aaron
  • #67
You were asking how the clock corrections are working in practice, weren't you?
Well, the answer is simple: as mentioned in Chapt. 4-6 of the technical GPS documentation ( http://www.publications.usace.army.mil/Portals/76/Publications/EngineerManuals/EM_1110-1-1003.pdf ) , the satellite clocks are reset from the ground as often as required to a) keep all satellite clocks against each other within 20 ns, and the satellite clocks as a whole against the ground clock within 1 ms. This guarantees that GPS results are correct to within a few meters.
  • #68
If it was a simple technical question, I don't think the thread would have gone on as long as it did (4 pages worth). Additionally, I think that Ashby's paper covers the technical aspects quite nicely, but it didn't seem to put the thread to rest.
Now, I can sympathize that not everyone necessarily has the necessary background to read Ashby's paper. But at that point the issue shifts from a merely technical question, to an educational one - how to understand the answers that are in the literature.
  • #69
nope...but I did get that pdf you sent and its a good reference, so thanks.
The original question was basically: a person at the north pole would view a GPS satellite's time as running at rate f1, but a person at the north pole would view a GPS satellite's time as running at rate f2. So would there be any position inaccuracy? The conclusion was of course no...
regards,
Aaron
  • #70
Right, positions determined recently when one more satellite was received, allow you to pick among two sufficiently distant solutions, and thus get by with one satellite less, so you have:
#satelites = #varibables
But the above is not a general rule. At some point you needed:
#satelites = #varibables + 1
