adjurovich
- 119
- 21
I am not sure if there is in fact a classical description of how it occurs, but I’d like to know if there isn’t too!
I am not sure about that, we can define the Newtonian gravitational field ##\mathbf F =m \mathbf g(r)##, where ##\mathbf F## is the force due to gravity on a mass ##m## and ##\mathbf g(\mathbf r)## the gravitational field.Hill said:In Newtonian mechanics, there is no "gravitational field". In general relativity, there is no "gravitational force".
What do you use this equation for, then?Hill said:In Newtonian mechanics, there is no "gravitational field". In general relativity, there is no "gravitational force".
There is a gravitational field in Newtonian's mechanics. However this field is instantaneous and that already bothered Newton and many people after him.adjurovich said:What do you use this equation for, then?
##g = \dfrac{F}{m}##
There is also gravitational field in classical mechanics, but Newton never truly understood gravity… but do we?
I disagree. In Newtonian mechanics you certainly can define a gravitational field. It just doesn't have any interesting dynamics on its own.Hill said:In Newtonian mechanics, there is no "gravitational field". In general relativity, there is no "gravitational force".
Since in our best theory of gravity the gravitational field does not exert a gravitational force, what does the question in the title of the thread refer to?adjurovich said:Newton never truly understood gravity… but do we?
I see. Anyway, the modern answer to that question is, it does not. Here is "the answer" from Gravitation by Misner, Thorne, and Wheeler:adjurovich said:I have asked about classical (more precisely Newtonian) description, not the relativistic one. You cannot expect from a high school student to know much about general theory of relativity?
He didn't spam your inbox. More likely you got a notification that he replied in your thread. Please be careful using the term "spamming" here. Thank you.adjurovich said:It’s better than spamming someone’s inbox
That would be the second paragraph in post #5, to which you've yet to respond.adjurovich said:I am not sure if there is in fact a classical description of how it occurs, but I’d like to know if there isn’t too!
A gravitational field is a region of space surrounding a mass where other masses experience a force of attraction. It is a vector field that points toward the mass creating the field, and its strength decreases with distance from the mass.
The gravitational force between two masses can be calculated using Newton's law of universal gravitation, which states that the force (F) is equal to the product of the gravitational constant (G), the masses (m1 and m2), divided by the square of the distance (r) between their centers: F = G * (m1 * m2) / r².
Mass is the source of the gravitational field. The greater the mass of an object, the stronger its gravitational field and the greater the force it exerts on other masses within that field. This is why massive objects like planets and stars have a significant gravitational influence on nearby bodies.
The gravitational force decreases with the square of the distance between two masses. This means that as the distance increases, the gravitational force becomes weaker. Specifically, if the distance is doubled, the gravitational force becomes one-fourth as strong.
Yes, gravitational fields exist in space and are not limited to the vicinity of massive objects like planets or stars. Every mass creates a gravitational field that extends throughout space, affecting other masses regardless of their distance, although the strength of the field diminishes with distance.
