How Does Gravity Escape a Black Hole?
In summary, the idea that gravitons escape the event horizon of a black hole is a common misunderstanding. Gravity is a field and a black hole's gravitational effects are not dependent on gravitons getting out of it. Gravitons are a hypothetical concept and their existence is not a part of general relativity. Additionally, it is not possible for a sudden absence of the sun to occur due to the principle of local energy conservation.
black hole 123
36
And how does graviton escape the event horizon? People say it's because those gravitons are "virtual particles" and can travel faster than light, yet many of the posts i read on here say virtual particles don't even exist. Also, gravity TRAVELS at the speed of light, if the sun is suddenly gone we'll still feel its gravity, so please don't tell me somehow the gravity from a black hole manages to travel faster than light. Doesn't this prove gravitons are wrong, and gravity really is curved spacetime? Or uses some other mechanism not the same as the other 3 forces?
Gravity doesn't have to "fight the black hole" it IS the black hole.
This is a common point of misunderstanding. Gravity is a field. The gravitational field of a black hole forms as the black hole is forming, so there IS no "getting out of" the black hole, it's just an existing field.
To add to what the others are saying:
The gravitational force between two objects is not caused by gravitons (assuming that there is such a thing as a graviton) moving from one to the other, so a black hole's gravitational effects do not depend on gravitons getting out of it.
Gravitons are a hypothetical concept that appears in some theories of quantum gravity, but they are no part of general relativity because it's not a quantum theory. If gravitons do exist, they will show up in the quantum mechanical description of how an object interacts with the local gravitational field in it's immediate vicinity.
This can't happen; it would violate local energy conservation. It is actually not trivial to formulate a thought experiment that can test the "speed of gravity" by changing gravitational sources, because of the requirement of local energy conservation, which means that sources of gravity can't be created or destroyed.
Related to How Does Gravity Escape a Black Hole?
1. What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, not even light, can escape from it. It is created when a massive star collapses in on itself.
2. How does gravity escape a black hole?
Gravity does not escape a black hole. In fact, it is the strong gravitational pull of a black hole that prevents anything from escaping, including light. This is known as the event horizon.
3. Can anything escape a black hole?
No, nothing can escape a black hole once it has crossed the event horizon. This is why black holes are often described as "cosmic traps" or "one-way doors".
4. How does the theory of relativity explain gravity in black holes?
According to the theory of relativity, gravity is the result of the curvature of space and time caused by massive objects. In the case of a black hole, the extreme mass and density causes a significant distortion in space-time, resulting in the strong gravitational pull.
5. Can black holes be observed or measured?
Black holes cannot be directly observed because they do not emit light. However, their presence can be inferred through their effects on surrounding matter and light. Scientists can also measure the gravitational pull of a black hole on nearby objects, providing evidence for its existence.
