How Does Integration by Parts Differ in Solving $\int x^8 \ln x^9 \, dx$?
  • MHB
  • Thread starter karush
In summary, the conversation is about solving an integral using the substitution method and then applying Integration by Parts. The final answer is $x^9\ln x - \frac{1}{9}x^9 + C$.
karush
MHB
3,269
$\Large{242.8.2.54} \\ $
solve by $u={x}^{8}$ then by IBP
$\displaystyle
I_{54}=\int{x^8}\ln{x^9} \, dx
=9\left(\dfrac{x^9\ln\left(x\right)}{9}-\dfrac{x^9}{81}\right) \\$
$u=x^8. \ \ du=8x^7 dx \ \ x=\sqrt[8]{u}$
how would IBP be any different?
I believe you'd want to use the substitution
$$t=x^9,\quad\dfrac{dt}{9}=x^8\,dx$$
so the integral becomes
$$\dfrac19\int\ln(t)\,dt$$
Now, to apply IBP, use
$$u=\ln(t),\,du=\dfrac1t\,dt;\quad dv=dt,\,v=t$$
Can you proceed from there?
$$t=x^9,\quad\dfrac{dt}{9}=x^8\,dx \\
IBP
$$\begin{align}
u&= \ln\left({t}\right) &dv&=dt\\
du&=\frac{1}{t}dt &v&=t&
\end{align}\\$$
$$\frac{1}{9}\left[uv-\int v \, du \right]
\implies
\frac{1}{9}\left[t \ln\left({t}\right)-\int t \frac{1}{t}dt\right]
\implies
\frac{1}{9} \left[t\ln\left({t}\right)-t\right]$$
back substitute $t=x^9$
$$\displaystyle
\frac{1}{9} \left[x^9\ln\left({x^9}\right)-x^9\right]+C$$
something ?
That's correct (and it's equivalent to the answer you gave in your initial post with the constant of integration added in).
I would have used an entirely different substitution...
$\displaystyle \begin{align*} \int{ x^8\ln{ \left( x^9 \right) } \,\mathrm{d}x } &= \int{ 9\,x^8\ln{(x)} \,\mathrm{d}x } \\ &= \int{ \frac{9\,x^9\ln{(x)}}{x}\,\mathrm{d}x } \end{align*}$
then with the substitution $\displaystyle \begin{align*} u = \ln{(x)} \implies \mathrm{d}u = \frac{1}{x}\,\mathrm{d}x \end{align*}$ we have
$\displaystyle \begin{align*} \int{ \frac{9\,x^9\ln{(x)}}{x}\,\mathrm{d}x } &= \int{ 9\,u\,\mathrm{e}^{ 9\,u }\,\mathrm{d}u } \end{align*}$
and then apply Integration by Parts.
karush said:
$\displaystyle I \;=\; \int{x^8}\ln{x^9} \, dx \;=\;x^9\ln x - \tfrac{1}{9}x^9 + C \\$
[tex]\text{We have: }\;I \;=\; 9\int x^8\ln x\,dx[/tex]
[tex]\begin{array}{ccccccccc}
u&=& \ln x && dv &=& x^8dx \\
du &=& \frac{dx}{x} && v &=& \frac{1}{9}x^9 \end{array}[/tex]
[tex]I \;=\; 9\left[\tfrac{1}{9}x^9\ln x - \tfrac{1}{9}\int x^8dx\right] \;=\; 9\left[\tfrac{1}{9}x^9\ln x - \tfrac{1}{81}x^9\right] + C[/tex]
[tex]I \;=\;x^9\ln x - \tfrac{1}{9}x^9 + C[/tex]
FAQ: How Does Integration by Parts Differ in Solving $\int x^8 \ln x^9 \, dx$?
What is the meaning of "242.8.2.54 int subst / IBP"?
"242.8.2.54 int subst / IBP" refers to a specific type of chemical substance or compound. The numbers and letters in the code may indicate its composition, origin, or purpose.
What is the function of "242.8.2.54 int subst / IBP" in scientific research?
"242.8.2.54 int subst / IBP" may have various functions in scientific research, depending on its specific properties and characteristics. It could be used as a reagent, catalyst, or as a means to study certain reactions or processes.
How is "242.8.2.54 int subst / IBP" synthesized or produced?
The process of synthesizing or producing "242.8.2.54 int subst / IBP" may vary depending on its composition and properties. It could involve mixing or reacting different chemicals or isolating it from a natural source.
Is "242.8.2.54 int subst / IBP" safe for human consumption?
Without specific information about the substance, it is difficult to determine its safety for human consumption. However, as a scientist, it is important to conduct thorough testing and analysis to ensure the safety of any substance before it is used or consumed.
What are the potential applications of "242.8.2.54 int subst / IBP" in various industries?
The potential applications of "242.8.2.54 int subst / IBP" may vary depending on its properties. It could have applications in the pharmaceutical, chemical, or agricultural industries, among others.
