How does it take a lot of skill to be a good plumber?
  • Thread starter timmeister37
In summary, the individual has considered various career options after leaving their previous job as an HVAC technician due to the extreme heat. They have heard about the potential job loss for truck drivers and are considering a plumbing program at a trade school, as suggested by their father. They question the level of skill required for plumbing and ask for clarification on what makes it a highly skilled occupation. They are curious about the difficulty of tasks such as moving hot and cold water lines, soldering pipes, and following building codes. They also question the use of lead pipes and the need for inspections in older homes.
timmeister37
124
25
I have been trained as an HVAC technician before, and I have worked as a residential HVAC technician, but I quit HVAC to go back into trucking because I could not bear to work in the hot attics (140+ degrees fahrenheit) in the summertime. I have heard that soon truck drivers will become obsolete and robots will be driving semi-trucks. When human truck drivers become obsolete, I will need to switch careers. I have been considering many different careers I could go into. My father recently told me that he had an epiphany. He said that I could attend a plumbing program at a trade school, and since I would then have had training in both HVAC and plumbing, I could be useful to large apartment complexes as a maintenance man.
I asked my father if plumbing is a highly skilled occupation, and he said that plumbing is a highly skilled occupation. I have never worked as a plumber, so I might be unaware of some sort of important facts that make plumbing a highly skilled occupation. But I don't see how plumbing would require a lot of skill & knowledge. In HVAC, one must learn all about electricity and how electric motors work, so I can see how HVAC is highly skilled. In plumbing, you don't even use electricity at all, except with water heaters. I see plumbing as just consisting of using an augur to clear out clogs in pipes and installing faucets mostly. I don't see how that would require an enormous amount of skill.
If you agree with my father that it takes a lot of skill to be a good plumber, what is it about plumbing that requires a lot of skill and training to be a good plumber?
-------------------------------------------------------------------------------------------------------Edited to add: I am just asking how it takes a lot of skill to be a good plumber out of curiosity. I don't deny that it takes a lot of skill to be a good plumber. Since I have never worked as a plumber, I am just asking this question to learn why it takes a lot of skill to be a good plumber.
Try renovating the bathroom in an old house some day, where you have to move your hot and cold lines. Without plumber's knowledge and skills, you'll quickly learn that its not as easy as it seems.
Do you know how to couple copper to lead pipes? Are your solder joints reliable? Did you set the place on fire soldering in a cramped crawlspace? And to top it all: is it all up-to-code? Will it pass inspection?
That last one is nothing to sneeze at. A layperson will have no idea what the local code requires. A plumber has it all in his head.
Likes phinds, atyy, BillTre and 4 others
I have never moved hot & cold water lines. Have you? If so, what made it difficult? Please elaborate.
No. But who would be using lead pipes in the year 2020? Hasnt it been well known for well over a century that lead pipes will lead to lead poisoning? These are not rhetorical questions.
So soldering pipes together is a major part of plumbing? I did not even know plumbers ever solder. I thought that plumbing pipes just screw on to each other.
Wouldn't knowing the codes only apply to plumbing work that is new construction?
If a plumber installs a new faucet in the sink of a twenty year old house, what government officials are going to inspect it?
I predict this thread will end up locked, since the very premise is "I know nothing of plumbing but I am sure it can't be hard". And yes, I read your PS. And the follow-up message which undermines it.
As for one example:
So you only plan on working on pipes in houses that were built after 1986?
Likes nuuskur, jim mcnamara and berkeman
I never said that i am sure that plumbing cannot be hard. Since everyone i have asked says that plumbing requires a lot of skill, i am confident that plumbing does require a lot of skill. Since i know so little about plumbing, i want to know how plumbing requires a lot of skill because i don't fully understand.As for one example:
No. I only plan on working on pipes in houses built after 1920. I said the last hundred years, not the last 34 years.
Lead pipes weren't banned until 1986.
Likes nuuskur, berkeman and timmeister37
I debated whether to reply to your thread, since on the face of it you seem quite mean-spirited in your question. Each of the trades on this long list take skills and learning and some sort of apprenticeship and often certifications:
https://tradesecrets.Alberta.ca/trades-occupations/trades-occupations-list/
To try to ask whether each one takes "a lot of skill" or whether one takes more skill than another seems unpleasant and misplaced to me. People should pursue occupations that interest them or that they know other people or relatives who work in them, and they should do their best to be the best they can be, IMO. I've done plenty of amateur electrician work and plumbing work and carpentry work on my own homes and helping my friends, but for sure professionals in each of those trades know way more than I do about those trades, and are much more skilled in those trades than I am.
I think that this is the only redeeming point in your post so far. Combining multiple trades can make you more valuable in some specialized employment sectors.
Likes russ_watters, atyy and jrmichler
What was your purpose in writing this? Are you trying to stir up drama?
Why would i make a thread trying to learn why plumbing is high skill if i already know plumbing is high skill?
  • Skeptical
Likes berkeman
I truly don't understand why everyone is ascribing these evil intentions to me. I just created this thread to learn about what makes plumbing high skill.
Higher than what?
Higher than what?
Higher than low skill
  • Haha
Likes nuuskur and undefined314
So far dave has listed soldering pipes together, which is most definitely a skill. Dave also listed the skill of moving hot & cold water lines. Dave also listed how one must know the plumbing codes, another skill.
Can anyone else either add something new or elaborate on what has already been said?
I am sure if a professional plumber was here, the professional plumber could list A LOT of plumbing skills that i don't know.
To try to ask whether each one takes "a lot of skill" or whether one takes more skill than another seems unpleasant and misplaced to me. People should pursue occupations that interest them or that they know other people or relatives who work in them, and they should do their best to be the best they can be, IMO. I've done plenty of amateur electrician work and plumbing work and carpentry work on my own homes and helping my friends, but for sure professionals in each of those trades know way more than I do about those trades, and are much more skilled in those trades than I am.I think that this is the only redeeming point in your post so far. Combining multiple trades can make you more valuable in some specialized employment sectors.
Ok berkeman, in thr plumbing work you did yourself at your own house and for your friends, did you ever need to research in a plumbing book to do the work? If so, what about plumbing did you specifically research?
Berkeman, i looked at your link. It was mildly interesting, but not extremely interesting.
I need to look at a plumbing book. That would prolly be more informative than anything else, short of doing the work myself.
Of course! I took classes on home improvement, bought books on home improvement (including plumbing chapters), talked with friends who had done similar work, etc. A lot of that stuff is not intuitive.
I've repaired plumbing for my sinks, toilets, dishwashers, vent pipes, etc. And I've done some limited soldering of pipes, which was quite hard to do well (despite my skills at soldering electronic parts). And each of those tasks gets harder with limited access. You mention working in very hot attics (I've been there too), but it's also quite hard to slither on your back through the dusty, dirty confined space below a home's flooring to get to a lot of the pipes that need attention. If you have any claustrophobia issues, being a plumber is probably not for you.
Likes russ_watters, atyy, jrmichler and 2 others
I've repaired plumbing for my sinks, toilets, diswhashers, vent pipes, etc. And I've done some limited soldering of pipes, which was quite hard to do well (despite my skills at soldering electronic parts). And each of those tasks gets harder with limited access. You mention working in very hot attics (I've been there too), but it's also quite hard to slither on your back through the dusty, dirty confined space below a home's flooring to get to a lot of the pipes that need attention. If you have any claustrophobia issues, being a plumber is probably not for you.
I had to go in those tight crawlspaces in HVAC as well. A lot of houses have the ducts and the air handler in the crawlspace.
I am overweight, and my obesity makes both working in very hot attics and slithering in crawlspace only about 2 feet high far more difficult
Likes atyy and berkeman
The direction of this topic has become ridiculous. Think about the work and decisions of plumbers! You need to be a human thinker here. So you believe plumbers do not need "alot of skill" to be any good? Can you
  • Change a kitchen garbage disposer
  • Repair or replace the (installed) air conditioning and heating system
  • Replace all of the pipes in a house
  • Remove and install air or air exhaust pipes & vents
Likes timmeister37
timmeister37 said:
my obesity makes ... slithering in crawlspace only about 2 feet high far more difficult
You know all those pipes you saw in crawlspaces? Who do you think works on them?
  • I don't know.
    [*]Repair or replace the (installed) air conditioning and heating system
    Yes, but that is HVAC, not plumbing
    [*]Replace all of the pipes in a house
    Not if it requires soldering.
    [*]Remove and install air or air exhaust pipes & vents
That is HVAC, not plumbing.
If a dishwasher breaks down due to mechanical issues, is that a plumber's territory? I thought that only hooking up the water supply to a dishwasher was a plumber's territory. I thought that repairing anything on a dishwasher other than the water supply was an appliance repairman's job, not a plumber's job.
It looks like @berkeman's experience with electrical / HVAC / plumbing / roofing / general construction is very similar to mine. I can verify everything he said above.
The total knowledge and experience needed for plumbing is similar to, if not greater than, that needed for HVAC. Do you know how to properly size, set up, and troubleshoot an AC unit for optimal cooling AND humidity control AND operating cost? Do you really understand the difference between a capillary and a TXV? If not, you are not a real HVAC tech.
In my state (Wisconsin), the water portion of any HVAC system that has circulating water must be installed by a licensed plumber. And that is enforced, as a somebody I know personally learned the hard way.
Likes russ_watters, timmeister37 and berkeman
If a dishwasher had a mechanical failure unrelated to the water line supplying the dishwasher with water, can you verify whose job it would be to repair the dishwasher, a plumber or an appliance repairman?
Then plumbing is a highly skilled job indeed.
Wouldn't one use a manual J calculation for that?
I used to know the differences in a lot of detail, but I have gotten rusty on HVAC. Capillary tubes are never used in residential HVAC. Capillary tubes are only used in icemakers and some walk-in freezers/walk-in coolers, as I recall. I know what a capillary tubes metering device looks like, and I know what a TXV metering device looks like.
TXV metering devices are sometimes used in both residential HVAC and commercial HVAC.
A TXV metering device works to keep a constant evaporator superheat. I don't think that a capillary tube metering device works to keep a constant evaporator superheat. I knew more about capillary tubes when I attended the HVAC program at a technical college.
I didn't know that.
We apparently all need to learn better the distinctions about the work of plumbers, "HVAC" people, and other repair-people.
Just a few tidbits of plumbing I've run across over the years, these are really basic but somewhat obscure examples:
  1. There are four different materials used for water supply lines and fittings in buildings; name them
  2. Some of those four types are compatible with each other, others are not. List the possible combnations and state which are directly compatible.
  3. What are some symptoms of incompatible combinations being used?
  4. What is done to avoid problems when incompatible combination are unavoidable?
  5. Of the materials you listed in 1), what are some common usage limitations of each?
  6. What is the common range of water pressure in a residence?
  7. What is the common water pressure in the city water mains?
  8. What material is commonly used for main sewer pipes under residences and office buildings?
  9. How are the sections joined?
  10. What method is used to replace a leaking section of sewer pipe?
  11. There is a customer that lives outside of the city without city services that is complaining no matter how much detergent is used in the washing machine, there are no suds. Why? Name two ways to correct the situation.
  12. What is the slope of a sewer line? Why?
  13. In multi-story buildings the sewer lines do not go directly to the main sewer under/in the basement. Why? What approach is used?
  14. What approach is used when a basement is below the level of the city sewer.
  15. You can often spot short lengths of 3-inch pipe sticking up out of a roof. Why? Where do they connect? What are they called?
  16. You have another customer out in the country without city services that complains the sinks and bathtub are slow to drain. Where does the water normally go when the system is operating normally?
  17. Same customer calls a year later and complains that water from the faucets starts fine but the flow soon decreases to a trickle. Why?
  18. Away from city services, water for landscaping is often obtained from what source?
  19. There is a galvanized water pipe under a house that goes thru and is embedded in a concrete foundation. The pipe has a small leak in it about 1/2 inch from the concrete. What method is used to repair the leak?
  20. Yet another country customer complains that no well water is coming from the faucets. You replace the well pump in the utility room with a centrifugal pump from the local hardware store. Still no water. Give three possible reasons why.
  21. A customer has a Summer cabin in the mountains and complains that every Spring he has to replace the buried water line from the well to the cabin, even though the line is drained every Autumn. Why? What is the solution?
That's the 'common' stuff I've run across, and my background is in Electronics, not the construction trades. Others here have pointed out other aspects you need to be aware of.
Enjoy the journey!
Cheers,
Tom
Likes jrmichler, berkeman, BillTre and 2 others
How can someone who has been in the HVAC business which likely involves soldering refrigeration lines have never noticed that other pipes in a house are soldered together? Any skill I have or work I have ever done puts my brain on alert. I notice the way 'things' are done once I've been involved in it. So I have to wonder what kind of blinders you are wearing.
Likes russ_watters
Enjoy the journey!
Cheers,
Tom
Excellent post, Tom!
My husband is a retired Union Pipefitter and Plumber:smile::smile:
Likes timmeister37
In HVAC, we braze the refrigerant lines to the unit, not solder them. I believe that the gas lines for a gas furnace screw on.
When i worked in residential HVAC, i focused on HVAC, not plumbing. Thats why i did not notice that plumbing lines are soldered on.
Then please ask him to contribute to this thread.
  • #31
@timmeister37 :
Instead of Physics Forums, you might want to try Renovate Forums. There's a much larger population of well-informed experts there. If plumbing turns out not to be suitable, you could also ask about other trades.
If you cannot get your weight under better control, you might also consider driving a garbage truck. No, I'm not being sarcastic nor joking. Recently a friend (a lightly built woman in her mid-20's) decided to give up her job managing a suburban pharmacy store in favour of being a garbage truck driver. It's more money, and she no longer has to tolerate tedious customers all day long.
  • Haha
Likes Tom.G
  • #32
Proper venting is a huge area of plumbing that most folks don't know exists. My suggestion is to get a handful of plumbing books. Not just one will do. Some will have things that others won't. Between them all you will soon make sense of it.
I've never seen brazed refrigeration lines in residential.
Likes timmeister37
  • #33
Just to satisfy my curiousity, what filler metal is used and what heat source? Oh, and what flux?
I assume that brazing is higher strength than ordinary solder, to withstand the high side pressure. By the way, what is a typical high side pressure in a central residential unit?
Cheers,
Tom
  • #34
I think you're missing the point. I only had to list one skill before your personal skill had been exceeded. I listed a half dozen, but would two dozen, or fifty, make the point better?
Lead pipes are already in place in old homes. Unless the customer wants to pony up the cash for a complete refit, a plumber needs to know how to go from lead to copper.
And you're right - it's not as simple as I'm making it out. Not all water pipes are for potable water. A plumber needs to know what ones can remain and what ones are a hazard.
timmeister37 said:
... i want to know how plumbing requires a lot of skill because i don't fully understand.
You know how. You know you don't have the skills, and you know you'd need to learn them to plumb.
Do you mean you want to know all the ways? That would be tantamount to a basic plumbing course.Where is this going? I feel there is an unasked question, still in the chamber.
Likes KWolf12
  • #35
Sorry, he is watching FOX news right now. Tomorrow I'll ask him:smile:
  • Wow
Likes KWolf12 and atyy
  • General Discussion
  • STEM Academic Advising
