How does one calculate the number of photons striking a surface per second?
In summary, to calculate the number of photons striking a surface per second, one needs to know the power of the light source (in watts), the energy of a single photon (calculated using the formula E = hc/λ, where h is Planck's constant, c is the speed of light, and λ is the wavelength of the light), and then divide the power by the energy of a single photon. The formula can be expressed as: Number of photons per second = Power (W) / (hc/λ). This calculation provides the rate at which photons impact the surface.
Danielk010
34
I am given the wavelength, number of waves, the wattage, and efficiency of the light bulb. I am also given the width and length of square surface, and the distance between the bulb and said surface.
For this part of the question, it says
"Assuming the emitted photons to be distributed uniformly in space, how many photons per
second strike a x mm by y mm paper held facing the bulb at a distance of delta x m?"
From the previous part of the problem, I calculated the photons emitted per hour and per second.
# of photons per second = wavelength * E / hc
I am more so stuck on where to start with this problem. I know dividing the photons per second by the area gets me the photon per area, but I am not sure how the distance is related to this part of the problem. If anyone can help, thank you.
What if the piece of paper were held 100 million kilometres from the light bulb?
Likes Danielk010
There would be very few photons that hit that paper depending on placement of paper?
Exactly.
Likes Danielk010
PeroK said:
Exactly.
Ooohhh. Thank you. Am I on the right track with photons per area? If so, how would I correlate the distance with the values I have mathematically? Would it just be photons per area * (displacement)^2 since the units would cancel out?
You are on the right track with (photons/area)/second. Imagine a sphere of radius R surrounding the source. All the energy emitted by the source per second has to go through the surface of that sphere. What portion of the energy goes through a rectangular area (x) × (y)?
If the sphere covers the source, then no photons would be passed through, depending on the type of material the sphere is made out of. That means that no energy from the photons goes through the rectangle area, right? I am still confused on the problem.
You missed my point. Put the x mm by y mm paper on the inside surface of the sphere. How many photons per second strike its surface?
(photons per second / x * y) 4πr^2?
Try some limiting cases. For example, if the paper gets really small, say, ##x \to 0##, does your answer give the result you'd expect? What if ##r \to \infty##? You said earlier that if the paper is far from the light source, only a few photons would strike the paper. Again, is that the result your formula predicts?
oh ok thank you. Would switching the x * y with the 4πr2 be accurate since as x * y grows the number of photons striking the surface would increase and as r decreases the number of photons striking the surface would decrease? Thank you for help.
This principle is the basis of so much in physics that I'm surprised you haven't previously encountered it.
For example, you could calculate how much of the Sun's energy reaches the Earth's surface, based on the distance and cross sectional area of the Earth.
The due date for the assignment has passed. I looked up the example you mentioned and I got the concept. Thanks for the help
FAQ: How does one calculate the number of photons striking a surface per second?
What is the basic formula to calculate the number of photons striking a surface per second?
The basic formula to calculate the number of photons (\(N\)) striking a surface per second is given by \(N = \frac{P \cdot \lambda}{h \cdot c}\), where \(P\) is the power of the light source in watts, \(\lambda\) is the wavelength of the photons in meters, \(h\) is Planck's constant (\(6.626 \times 10^{-34} \, \text{Js}\)), and \(c\) is the speed of light in a vacuum (\(3 \times 10^8 \, \text{m/s}\)).
How do you determine the power of the light source (P) in the formula?
The power of the light source (\(P\)) can be measured using a photometer or a power meter. It is the amount of energy the light source emits per second, measured in watts (W).
What role does the wavelength (\(\lambda\)) play in the calculation?
The wavelength (\(\lambda\)) of the light determines the energy of each photon. Shorter wavelengths (e.g., blue light) have higher energy photons, while longer wavelengths (e.g., red light) have lower energy photons. The number of photons is inversely proportional to the wavelength.
How do you convert the wavelength from nanometers to meters for the calculation?
To convert the wavelength from nanometers (nm) to meters (m), you divide the wavelength value by \(10^9\). For example, if the wavelength is 500 nm, it would be \(500 \times 10^{-9}\) meters.
Can you provide an example calculation using the formula?
Sure! Suppose you have a light source emitting 10 watts of power with a wavelength of 600 nm. First, convert the wavelength to meters: \(600 \, \text{nm} = 600 \times 10^{-9} \, \text{m}\). Then use the formula: \(N = \frac{10 \, \text{W} \cdot 600 \times 10^{-9} \, \text{m}}{6.626 \times 10^{-34} \, \text{Js} \cdot 3 \times 10^8 \, \text{m/s}}\). This simplifies to \(N \approx 3.02 \times 10^{19}\) photons per second.
