B How does polarisation in nature work?
Lights reflecting off horizontal surfaces like roads, water, or snow are horizontally polarized due to the interaction of incoming light with the vibrating electrons in these materials. When vertically polarized light enters water, it bends downwards, causing the electrons to vibrate edge-on and not radiate in the same direction. The polarization phenomenon applies across the electromagnetic spectrum, with horizontal waves inducing easier current flow in parallel wires, leading to coherent wavefronts. In contrast, water's conductivity is more complex, as induced currents are not limited to the surface, affecting the reflection and transmission of light based on the angle of incidence. The discussion highlights the importance of Brewster's Angle in understanding light polarization.
jackiepollock
Why are lights reflecting off horizontal surfaces like the road, water, or snow horizontally polarized? How does the process happen?
Science news on Phys.org
The shine from water comes from electrons in the water which are vibrating in response to the electric field of the incoming light and causing re-radiation. When a vertically polarised ray of light enters water, it is bent downwards. The charges now vibrate edge-on to the viewer, and do not radiate in their direction.
The phenomenon of polarisation is the same over the whole electromagnetic spectrum and often it's useful to think in terms of radio waves and the way they interact. It's very complicated and not intuitive (imo) so here's a noddy explanation which has some holes in it but it carries the main message about how EM waves interact with 'substances'.
A horizontally polarised wave will excite the electrons in a long horizontal wire to oscillate and charges flow 'easily' through the wire when the E field is parallel with the wire. This will cause the wave to be (re-radiated) reflected and a 'coherent' wave front is formed from all along the wire. If the wire is not parallel to the plane of the E field, the 'component' of the E field is not parallel to the wire so less induced current will flow and the re-radiation is less. A wire at right angles to the E field will not disturb the incident wave at all because no current will flow along it. For this reason, a grid of parallel wires makes an excellent polariser for microwaves.
A metal plate conducts current so well that the induced currents can be considered to be just on the (2D) surface; it's a simpler system. Waves of any polarisation tend to be reflected well because there's an 'easy' current path across the surface. But water doesn't conduct like metal and the currents that are induced, don't just flow in the surface (not enough current) and you have to deal with a 3D situation where waves will travel through the water as well as being reflected. The angle of the E vector and the direction of the incident wave affect how much is reflected and how much is transmitted. The horizontal component reflects better than the vertical component. The proportion of reflected and transmitted energy depends on the materials involved and the angle of incidence.
PS there is a common explanation of the mechanism of selecting the polarisation of light which is referred to the 'picket fence' model. You need to read this with care, always because it ain't anything like that in most cases. :smile:
Likes DaveE, Ibix and joseph707
hutchphd said:
Someone should say the magic words "Brewster's Angle". Here you go
https://en.wikipedia.org/wiki/Brewster's_angle
All good stuff. Just a problem knowing where to stop. I remember finding Brewster a big jump in understanding. :smile:
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
