How does pressure act in all directions if gravity is downward only
In summary, the conversation discussed the concept of pressure in liquids and solids. It was noted that in a liquid, the molecules are free to move and spread out due to the presence of a horizontal force, which may come from a pressure difference between the liquid and air. This force is also present in solids, but it requires more force to break the bonds between molecules. It was also mentioned that gravity is not the only force acting on molecules, as there is also internal stress from other molecules. Additionally, fluids deform under shear stress, causing them to "slump" down until the principal stresses are equal and there are no shear stresses.
iVenky
212
I have a fundamental question about the pressure and I am not sure if my reasoning is correct.
Let's take an example of 7 stones shown below. They don't fall because the center of mass of each stone is falling right under the stone below. If I replace the same thing with a liquid, and we know that the molecules are free to move in a liquid, they all spread out and become flat until the net potential energy is minimum. My fundamental question is what triggered this horizontal force in the first place if gravity is a downward (vertical force). There needs to be some horizontal force to make the molecules move in the horizontal direction. Is it because there is some horizontal force present already in a liquid even in the absence of gravity that makes the molecules move away from each other due to the pressure difference between air (more gaps) and liquid? And it's the same in all directions because only then there is no net force present on the molecule itself that stops it from creating gaps in the liquid?
If that's the case, even solids experience this pressure difference or net force acting on it due to the atmosphere but it doesn't move like liquid because it requires more force to break the force between the molecules. Is this intuition of pressure right?
Likes Leo Liu
I think you are getting at the right idea. You can try and analyse what's happening by considering a small parcel of water, which will be acted upon by pressure forces from all the surrounding water (surface forces) in addition to its weight (body force). Even in a direction orthogonal to the gravitational field, in a non-equilibrium situation the pressure forces on either side of the parcel may differ in magnitude which will result in the parcel accelerating horizontally too.
Likes vanhees71
And don't forget that at any finite Temperature everything is constantly wiggling.
Likes Lnewqban
iVenky said:
... My fundamental question is what triggered this horizontal force in the first place if gravity is a downward (vertical force). There needs to be some horizontal force to make the molecules move in the horizontal direction.
That vertical arrangement is impossible to achieve (for more than few seconds perhaps) if you replace the stones, which enjoy some superficial friction, with steel ball bearings or magnets.
Even having a vertical direction, gravity will be the motor to take each piece to the lowest possible level.
Gravity is not the only force acting on the molecules. There is also the internal stress from the other water molecules. This is an internal force so it cannot cause an acceleration of the center of mass, but it certainly can make the liquid spread horizontally.
Fluids deform under shear stress. In a “pile” the stress is primarily axial compression. This means that the principal stresses are unequal, and any time that is the case you will have shear stresses at 45 degrees. So the fluid will “slump” down until the principal stresses are equal and you are left with only an isotropic pressure and no shear stresses.
Likes Leo Liu, vanhees71 and etotheipi
Related to How does pressure act in all directions if gravity is downward only
What is pressure and how does it act in all directions?
Pressure is a measure of the force exerted on a surface per unit area. It acts in all directions because it is caused by the collisions of particles with the surface.
How does gravity affect pressure?
Gravity only affects pressure in the vertical direction, as it is the force that pulls objects towards the center of the Earth. This means that pressure is greater at lower altitudes due to the weight of the air above.
Why does pressure act in all directions if gravity is only downward?
Pressure acts in all directions because it is caused by the collisions of particles with the surface, not just the force of gravity. This means that even though gravity pulls objects downward, the particles in the air are still colliding with the surface from all directions.
How is pressure distributed in a fluid?
In a fluid, pressure is distributed evenly in all directions. This is because the particles in a fluid are constantly moving and exerting pressure on all surfaces they come in contact with.
Does pressure change with depth?
Yes, pressure increases with depth in a fluid because the weight of the fluid above increases. This is known as hydrostatic pressure and is the reason why deep sea creatures experience greater pressure than those at the surface.
  • Mechanics
11K
15K
