MHB How Does Proposition 7 Support Proposition 15 in Dummit and Foote?
Math Amateur
MHB
I am reading Dummit and Foote Section 9.5 Polynomial Rings Over Fields II and need some help and guidance with the proof of Proposition 15.
Proposition 15 reads as follow:
Proposition 15. The maximal ideals in F[x] are the ideals (f(x)) generated by irreducible polynomials. In particular, F[x]/(f(x)) is a field if and only if f(x) is irreducible.
Dummit and Foote give the proof as follows:
Proof: This follows from Proposition 7 of Section 8.2 applied to the Principal Ideal Domain F[x].
My problem
- can someone show me how Proposition 15 above follows from Proposition 7 of Section 8.2 (see below for Proposition 7 of Section 8.2)
I would be grateful for any help or guidance in this matter.
PeterDummit and Foote - Section 8.2 - Proposition 7
Proposition 7. Every nonzero prime ideal in a Principal Ideal Domain is a maximal ideal.[This problem has also been posted on MHF]
My problem
So in one direction, the conditional is obvious. That is,
Suppose f(x) is reducible:
Then f(x) = g(x)*h(x) for polynomials g and h of degree less than f, which means that
(g(x) + \langle f(x) \rangle)\,(h(x) + \langle f(x) \rangle)
=(f(x) + \langle f(x) \rangle)
=(0 + \langle f(x) \rangle)
Which means that $F[x]/\langle f(x) \rangle$ is not a domain, and therefore not a field.
Now for the other direction, we'll need that proposition:
Suppose f(x) is irreducible:
Because f(x) is irreducible, we know that $\langle f(x) \rangle$ is a prime ideal.
By proposition 7, since F[x] is a principal ideal domain, we know that $\langle f(x) \rangle$ is a maximal ideal.
Finally, since $\langle f(x) \rangle$ is a maximal ideal and F[x]≠{0} is a commutative ring, we know that $F[x]/\langle f(x) \rangle$ is a field.
Thus, the proof is complete.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
