How does Python tell that an integer is actually an integer?
In summary,The first example is. For instance I have given you a binary '0b1100010' does it represent an integer or string ? How python understands the difference ? The second example was obvious thing so I have deleted that.We're getting some edit lag ... I deleted the post you just asked about because of a bit in the first post which I didn't see the first time, and don't see now. Ghosts, or something.
  • #36
Arman777 said:
I meant this
Then you are using the wrong operation. You don't want to convert an integer to a string. You want to convert a string (the message) into an integer (or a sequence of integers).
Arman777 said:
In my previous post, I was trying to say that you'll need a lot of storage if you store the key as binary. But an ASCII key will be more useful in terms of storage.
You are very confused.
First, as I have already pointed out, "binary" is not a Python data type. What you are calling "binary" are Python strings that contain "0" and "1" characters that can be interpreted as the bits in a binary representation of an integer, but that does not mean you should actually use this for any kind of arithmetical or logical operation. That's not what the bin() function is for.
You say this bin() conversion is an intermediate step, but I don't think you've fully thought through what you are doing. If you already have an integer representing a character in the message and an integer representing a character in the key, you can just xor them directly in Python. There is no need to convert them into these "binary" strings.
Arman777 said:
If your message is "password," and if you want to make the XOR encryption "unbreakable," you need to create a random binary key that is 64 bits long.
Yes, and this is a 64-bit integer. It's not a string of 64 bytes that are either "0" or "1".
Arman777 said:
For instace, I have generated a random binary key. So for an unbreakable message you'll need to store this.
0000110011010000111111100100101110110010010011110110110000101011
but if you convert this into ASCII (or as ASCII key), you'll need to store just
♀ÐþK²Ol+
First, most of those characters aren't ASCII characters, so the term "ASCII" is incorrect.
Second, since what you have is a 64-bit integer, you should just represent it as a Python integer and do Python operations on it directly as an integer.
Arman777 said:
Here, the only problem is that the binary representation of the key can also represent the unprintable ASCII characters.
The "unprintable" characters aren't ASCII characters to begin with, as noted above. But more important, viewing them as "characters" makes no sense. As above, you have a 64-bit integer. You can represent integers directly in Python as integers.
Arman777 said:
Instead of turning 67 and 45 into bytes and then doing XOR bitwise I could have just do
bin(67 ^ 45)
which gives the correct answer. This approach will definately shorten my code
Exactly! Except that there is no need for the bin() function anywhere. You have an integer; if you want to convert it to a character, you call ord() on it, not bin().
Arman777 said:
You guys are giving hints but I cannot understand something that i don't know...
What are you talking about? You just did understand it (in what I quoted above and responded to with "Exactly!").
Arman777 said:
Hex is a good approach
What? Why are you throwing away the right answer right after you found it?
Likes Arman777
Technology news on Phys.org
  • #37
Again, the OP seems to be confused about the difference between a numeric digit character, like '0' and a numeral, like 0.
The character '0' has an ASCII code of 48 (or 0x30 in hex or b110000 in binary). The number 0 has all its bits cleared to 0.
Likes Arman777
  • #38
Yes you are right I have realized that later on.
Yes you are right. The problem was I was not aware of that kind of operation was avaliable in python. So that was why I was trying to strange stuff.
Yes I have also realized that
Well It was a late enlightenment for me. In my head I was keep repeating what these guys want.
I was just thinking that can be a good idea. But I can also change the encrypted message to to a list of integers (or hex) which seems more reasonable. Such as
encrypted_message = encryptXOR('I have a dream', '999')
decrypted_message = decryptXOR(encrypted_message, '999')
print(encrypted_message)
print(decrypted_message)
will output
[112, 25, 81, 88, 79, 92, 25, 88, 25, 93, 75, 92, 88, 84]
I have a dream
  • #39
I think @arman here means that he realizes hex can be useful for external representation of arbitrary 8 bit values; hex is much more compact and easier to read than strings of 0's and 1's and does not suffer the problem of unprintable characters of direct extended ASCII rendering.
The light regarding internal representation does seem to have clicked on :biggrin:
Likes Arman777
  • #40
Yes exactly. I was talking about external representation
  • #41
I think Python determines types at runtime unlike other languages like C++.
  • #42
That goes a long way towards explaining why I spent the last couple of pages thinking that at least one of us is an idiot. Sure, you can do the whole thing in display-types ; it's a CLI ; machine efficiency isn't an issue.
What course/textbook ? what's the title of the chapter ? What's the exact wording of the problem ?
(ie: "summary"),
What coding, language, application constructs do you think would be useful ?
(ie: "equations")
What have you accomplished, and how are you stuck ?
  • #43
No one has to be an idiot. Its important to learn from our mistakes and we may not be know everything.
I have finished the coding actually. I even created a GUI
You can check here
https://github.com/seVenVo1d/random/tree/master/XOR%20Encryption
I could have shared the code here but the site is giving errors.
  • #44
Interesting the word 'pointer' was used once in this whole thread, didn't see registers mention either. Study an introduction into assembly language then the OP should be able to easily understand..
  • Skeptical
Likes pbuk
  • #45
How do you think a knowledge of assembly language and CPU architecture will help the OP understand how Python remembers that a variable holds an integer value?
  • #46
Your link is wrong.
I looked at the non-gui code.
This actually works with unicode, not just ascii. You can happy type accented letters such as å, chinese characters such as 龙, and emoji such as 🔦 into it, and it'll still work. One of the benefits of Python 3.
As a further exercise, you might want to change the output into some kind of more compact format. A cyphertex of "A@E3" might be more useful and portable than "0x1F,0x02,0x3435".
  • #47
lyuc said:
Your link is wrong.
Thats possible. I am changing the names and the code itself most of the times.
I have thought about it and limit the output only printible characters or as you have pointed out I could have removed the '\x' in front of them
Thanks for checking it out.
  • #48
The lazy way to do it would be to take the raw bytes and then use base64 encoding, or uuencode.
