How does refraction of light take place?
In summary, the conversation discusses the topic of refraction of light and why it shifts towards the normal when traveling from a rarer to denser medium. The concept of conservation of momentum is also brought up, with the question of why light does not bend away from the normal with the same angle it bends towards it. The density and index of refraction of FC-75, a transparent fluorocarbon, is mentioned as an example of how denser liquids do not always have a higher index of refraction. The conversation also suggests reading more about the topic for a better understanding.
Parbat
29
how does refraction of light take place?And why does it always shift towards the normal while traveling from rarer to denser medium,why not away from normal?
Science news on Phys.org
Did you check Wikipedia?
Conservation of momentum.
If it is conservation of momentum,then why doesn't the light bend away from the normal
with the same angle it bends towards normal?there would also be conservation of momentum,is'nt it?
Do you think diffraction is the cause of refraction?
I don't understand what you mean. When light enters a more optically dense medium, it refracts towards the normal. When it exits back to the less dense medium, it refracts away from the normal.
Here is as good an explanation that I know of. Read the paragraph titled "Refraction" at this link:
http://esfscience.wordpress.com/category/a2-physics/page/2/​
(You are looking for this figure:
[PLAIN]http://esfscience.files.wordpress.com/2008/10/soldiers.gif?w=300&h=260)
Bob S said:
The density of the inert transparent fluorocarbon FC-75 is 1.76 (MORE than water), and the index of refraction is 1.276 (LESS than water). Denser liquids do not always have a higher index of refraction.
I am sure the OP meant denser in the sense of having a higher refractive index, not in the mass-per-unit-volume sense of the word.
Related to How does refraction of light take place?
1. What is refraction of light?
Refraction of light is the bending of light as it passes through different mediums, such as air, water, or glass. This occurs because light travels at different speeds in different mediums, causing it to change direction.
2. How does refraction of light occur?
When light passes through a medium with a different density, the speed of light changes, causing it to bend. This is due to the change in the medium's refractive index, which is a measure of how much light is bent in that medium.
3. What factors affect refraction of light?
The refraction of light is affected by the angle at which the light enters the medium, as well as the difference in refractive indices between the two mediums. The wavelength of light also plays a role, with shorter wavelengths (such as blue light) being bent more than longer wavelengths (such as red light).
4. What is the law of refraction?
The law of refraction, also known as Snell's law, states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the refractive indices of the two mediums.
5. How is refraction of light used in everyday life?
Refraction of light is used in a variety of everyday objects, such as eyeglasses, lenses, and prisms. It is also used in optical instruments such as microscopes and telescopes, as well as in the production of fiber optics for communication and medical imaging.
