How does spin relate to the symmetry of a particle?
In summary, the spin statistics theorem states that particles with half integer spins are anti-symmetric while particles with integer spins are symmetric in many-particle systems. This property is important in understanding the symmetry of identical particles. The proof in Weinberg's "Quantum theory of fields" is considered the best as it covers all spin cases, while most textbooks only cover the simple cases relevant to the Standard Model.
kregg87
Why are particle with half integer spins anti-symmetric while integer spin particles are symmetric? Or in other words, how does spin relate to the symmetry of indentical particles?
This is the spin statistics theorem. Google will find many references (it's hard to overstate its importance) but I am not aware of any proofs that work for an I-level thread.
One thing you do want to be clear about (you may already know this, but it's not certain from your post): The symmetry and anti-symmetry we're referring to is a property of many-particle systems. If the wave function of the entire system changes sign when any two particles are exchanged, we say that is is anti-symmetric, while if the wave function is unchanged we say it is symmetric.
I'd say the proof in Weinberg's, Quantum theory of fields is the best one in the sense that it treats the general case of any spin. That's A level. In most other textbooks you find the treatment of the most simple cases of spin 0, 1/2, and 1 (relevant for the elementary particles in the Standard Model), which is I level. In Germany the introduction to QFT is in the advanced undergraduate course (leading towards an MSc degree).
FAQ: How does spin relate to the symmetry of a particle?
What is spin and how is it related to the symmetry of a particle?
Spin is a fundamental property of particles, similar to mass or charge. It refers to the intrinsic angular momentum of a particle, which cannot be explained by its physical shape or movement. The symmetry of a particle is related to its spin because the spin value determines how the particle behaves under certain transformations, such as rotations or reflections.
How is spin measured and quantized?
Spin is measured in units of Planck's constant divided by 2𝜋, denoted as ħ. This unit is known as a spin number or spin quantum number. The spin of a particle can only take discrete values, meaning it is quantized. For example, electrons have a spin quantum number of 1/2, while photons have a spin of 1.
What is the relationship between spin and angular momentum?
Spin is a form of angular momentum, but it is distinct from orbital angular momentum, which is associated with the movement of a particle. Spin is an intrinsic property of a particle and does not involve any physical movement, but it still contributes to the total angular momentum of a system.
How does the spin of a particle affect its properties?
The spin of a particle can affect its properties in several ways. For example, particles with half-integer spin, such as electrons, are fermions and follow the Pauli exclusion principle, which states that no two identical fermions can occupy the same quantum state. Particles with integer spin, such as photons, are bosons and do not follow this principle.
How does spin relate to the concept of symmetry breaking?
Symmetry breaking is a phenomenon in which the symmetry of a system is not preserved under certain conditions. In particle physics, the concept of symmetry breaking is closely related to spin. For instance, when a particle with zero spin decays into two particles with spin, the original symmetry of the system is broken. This allows for a better understanding of how particles behave and interact with each other.
