How does stimulated emmision work?
In summary, stimulated emission is a physical process that involves a photon stimulating an atom in a higher energy state to drop to a lower energy state, resulting in a coherent interference between the incoming photon and the stimulated photon. This process was discovered by Einstein and is based on the principle of detailed balance, which ensures that the rate of photon emission and absorption are equal in a state of thermal equilibrium. Mathematical models for this process can be found online and require familiarity with statistical mechanics and blackbody radiation.
Superposed_Cat
388
Hi all, I was wondering mathematically how stimulated emission works, could someone please explain it more concisely than wikipaedia? Thanks for any help...:shy:
Mathematically? Stimulated emission is a physical process where a photon stimulates something which is in a higher energy state to drop to a lower energy state where the energy difference is the same as the energy of the photon. The result is a coherent interference between the incoming photon and the the stimulated photon.
The above description is general in that it applies to masers (microwave - molecular transitions) as well as lasers (atomic transitions).
There has to be some mathematical relation/equation/formulism surely?
I heard that einstein discovered stimulated emission, he didn't do that heuristically.
Einstein used the principle of detailed balance. Essentially, when the atoms are in thermal equilibrium with radiation at a given temperature, they should reach a steady state equilibrium. At this state, the rate of photons emitted by a transition from a higher to lower energy level, [itex]m \rightarrow n[/itex] must be equal to the rate of photons absorbed, exciting the lower level to the higher level [itex]n \rightarrow m[/itex]. So you need to balance the two rates.
What Einstein found was that the only way for this to work is to include not only spontaneous emission, but also stimulated emission, otherwise there is no way for the thermodynamics to be consistent. You ask for mathematical models, but these are quite easy to find online and I didn't feel the need to write them out here. Here are two nice sources, which assume familiarity with statistical mechanics and blackbody radiation:
http://en.wikipedia.org/wiki/Einstein_coefficients (see "detailed balancing")
http://farside.ph.utexas.edu/teaching/qmech/Quantum/node119.html
Likes 1 person
FAQ: How does stimulated emmision work?
What is stimulated emission?
Stimulated emission is a process in which an atom or molecule in an excited state releases a photon of the same energy and phase as the incident photon, resulting in the amplification of light.
How does stimulated emission occur?
Stimulated emission occurs when an external photon with the same wavelength and phase as the excited atom or molecule is introduced. This external photon stimulates the atom or molecule to release a photon of the same energy and phase, resulting in the amplification of light.
What is the role of stimulated emission in laser technology?
Stimulated emission is the basis for laser technology. In a laser, a medium such as a crystal or gas is excited, and then stimulated emission is used to produce a coherent, intense beam of light with a specific wavelength and phase.
What is the difference between spontaneous emission and stimulated emission?
Spontaneous emission is a random process in which an excited atom or molecule releases a photon without any external stimulus. On the other hand, stimulated emission is a non-random process in which an external photon stimulates the release of a photon of the same energy and phase as the incident photon.
What are some real-world applications of stimulated emission?
Stimulated emission has numerous applications in various fields such as telecommunications, medical treatments, and materials processing. Lasers, LED lights, and optical amplifiers are examples of technologies that utilize stimulated emission.
