How Does Subtracting a Limit Value Affect Convergence?
In summary, to prove that $\displaystyle \lim_{x\to a} f(x) = L$ if and only if $\displaystyle \lim_{x\to a} [f(x) - L] = 0$, we need to show that for every $\epsilon>0$, there exists a $\delta>0$ such that $0<|x-a|<\delta \Rightarrow |f(x)-L|<\epsilon$. This can be proven by taking $\delta_1 = \delta_2$ and using the definition of a limit.
Amad27
412
Prove that $\displaystyle \lim_{x\to a} f(x) = L \space \text{if and only if} \space \lim_{x\to a} [f(x) - L] = 0$ Provide a rigorous proof.
I am not sure what he has given to us.
Is $\displaystyle \lim_{x\to a} f(x) = L$ true?
So,
$|f(x) - L| < \epsilon$ for $|x - a| < \delta_1$ some $\delta_1$
$$\lim_{x\to a} f(x) - L = 0 \implies |f(x) - L| < \epsilon \space \text{such that} \space |x - a | < \delta_2$$
I feel we need to prove that $\delta_1 = \delta_2$ Can someone confirm this?
But how do we prove this?
I think your idea is correct but I would write it down as follows.
To prove (the other direction is similar):
$$\lim_{x \to a} f(x)=L \Rightarrow \lim_{ x \to a}[f(x)-L]=0$$
Proof
Let $\epsilon>0$, as $\lim_{x \to a} f(x)=L$ there exists a $\delta>0$ such that
$$0<|x-a|<\delta \Rightarrow |f(x)-L|=|[f(x)-L]-0|<\epsilon$$
But that means we've found for every $\epsilon>0$ a suitable $\delta$ such that the above statement holds, that is, $\lim_{x \to a} [f(x)-L]=0$.
FAQ: How Does Subtracting a Limit Value Affect Convergence?
What is a rigorous proof of a limit?
A rigorous proof of a limit is a mathematical technique used to show that a function approaches a specific value, known as a limit, as the input approaches a certain value. It involves using logical reasoning and mathematical principles to demonstrate that the function behaves in a certain way, leading to the limit value.
Why is a rigorous proof of a limit important?
A rigorous proof of a limit is important because it provides a solid mathematical foundation for understanding the behavior of functions. It helps to ensure that the limit value is accurate and can be relied upon in various mathematical and scientific applications.
What are the key steps in a rigorous proof of a limit?
The key steps in a rigorous proof of a limit include defining the limit, setting up the necessary mathematical equations, using the definition of a limit to manipulate the equations, and showing that the limit value is reached through logical deductions and mathematical operations.
How do you know if a rigorous proof of a limit is valid?
A rigorous proof of a limit is considered valid if it follows the accepted mathematical principles and logical reasoning. It should also be able to withstand scrutiny and be replicable by others using the same techniques and assumptions.
Can a rigorous proof of a limit be used for all functions?
No, a rigorous proof of a limit may not be applicable to all functions. Some functions may not have a limit, while others may require more advanced mathematical techniques to prove the limit. It is important to carefully consider the properties and behavior of a function before attempting a proof of its limit.
