How does surface capacitive touchscreen work in detail?
In summary: This method is more accurate than using current meters. In summary, a surface capacitive touchscreen has a conductive layer with attached electrodes that apply AC signals. When a conductive material, such as a finger, touches the layer, it affects the capacitance between the electrodes and the layer, causing a change in voltage that can be measured with voltage meters attached to the electrodes. The layer is typically modeled as a 2D conductive plane, and its charge/voltage/current distribution can be calculated with an electrostatic field solver.
genxium
141
It's pretty easy to find the "working principle" of surface capacitive touchscreen like http://www.elotouch.com/Technologies/SurfaceCapacitive/howitworks.asp
Roughly speaking, I know that
  • A surface capacitive touchscreen has a conductive layer to which some electrodes are attached
  • The electrodes apply voltage across the layer
  • When some conductive material, e.g. finger touches the layer a portion of current is drawn yielding numbers' changes in the sensors attached to the electrodes
  • According to the numbers read from sensors, one calculates the touch location
Here're the questions:
  • Should the electrodes apply DC or AC signals to the layer?
  • How is the "conductive layer" modeled, i.e. is it regarded as a 2D conductive plane ? Or is it regarded as a 3D conductive block? In either case, how to calculate or approximately guess the charge/voltage/current distribution when the layer is idle/touched?
  • What are proper sensors to attach to the electrodes, e.g. voltage metres or current metres or sth else? Why?
1. The electrodes apply AC signals to the layer.2. The "conductive layer" is typically modeled as a 2D conductive plane. The charge/voltage/current distribution can be calculated with the help of an electrostatic field solver, such as a finite element solver.3. Voltage meters are typically used as sensors. This is because when a finger touches the layer, it affects the capacitance between the electrodes and the conductive layer, causing a change in voltage that can be measured.
Related to How does surface capacitive touchscreen work in detail?
1. How does a surface capacitive touchscreen work?
A surface capacitive touchscreen works by using a layer of conductive material, typically indium tin oxide, on the surface of the screen. When a finger touches the screen, it creates a capacitance, or change in electrical charge, in the conductive layer. This change in charge is detected by the device's controller, which then calculates the location of the touch based on the amount of charge and the position of the touch.
2. How does the conductive layer on a surface capacitive touchscreen detect touch?
The conductive layer on a surface capacitive touchscreen works by using a process called mutual capacitance. This means that the layer forms an electrical field that is constantly being measured by the device's controller. When a touch occurs, it disrupts the electrical field, and the controller can detect this change, allowing it to determine the location of the touch.
3. What is the difference between a surface capacitive touchscreen and other types of touchscreens?
Surface capacitive touchscreens differ from other types of touchscreens, such as resistive or infrared touchscreens, in the way they detect touch. While resistive touchscreens use pressure to detect touch and infrared touchscreens use beams of light, surface capacitive touchscreens use changes in electrical charge to detect touch. This allows for a more responsive and accurate touch experience.
4. Are surface capacitive touchscreens more durable than other types of touchscreens?
Yes, surface capacitive touchscreens are generally more durable than other types of touchscreens. This is because they do not have any moving parts or layers that can wear out over time. The conductive layer is also protected by a layer of glass or plastic, making it less susceptible to damage. However, they are still prone to scratches and cracks like any other screen.
5. Can a surface capacitive touchscreen work with any type of touch, or only with fingers?
A surface capacitive touchscreen can work with any conductive material, not just fingers. This includes a stylus or any object with a conductive tip. However, it may not work with gloves or other non-conductive materials unless they have a conductive coating. This is because the conductive layer needs to be disrupted in order for touch to be detected.
  • Electrical Engineering
  • Classical Physics
  • Electromagnetism
