How Does Temperature Affect the Buoyancy of an Iron Cube in Mercury?
In summary, when the temperature of the liquid mercury in a bowl is raised from 0 degrees Celsius to 30 degrees Celsius, the iron cube floating in it will float higher due to the decrease in density of the mercury. The fraction of volume submerged will also increase by approximately 0.25%. This is calculated by comparing the initial and final volumes of the iron and mercury and using the coefficient of volume expansion for each substance.
Freye
28
An iron cube floats in a bowl of liquid mercury at 0degrees C.
a) If the temperature is raised to 30degrees C, will the cube float higher or lower in the mercury?
b)By what percent will the fraction of volume submerged change?
[tex]\beta[/tex] mercury=180 X 10^-6
[tex]\beta[/tex]iron=35 X 10^-6
[tex]\Delta[/tex] V=[tex]\beta[/tex]V_1[tex]\Delta[/tex]T
[tex]\rho[/tex]=m/V
[tex]\rho[/tex]_solid/[tex]\rho[/tex]_fluid X 100 = % of submerged solid
NOTE: all Greater than or equal to signs are meant as only greater than signs, I just couldn't find them in the Latex Reference
a)
Since the iron floats in the mercury, V_1mercury [tex]\geq[/tex] V_1 iron, also [tex]\beta[/tex]_mercury [tex]\geq[/tex] [tex]\beta[/tex]_iron
Therefore [tex]\Delta[/tex]V_mercury [tex]\geq[/tex] [tex]\Delta[/tex]V_iron
then since [tex]\rho[/tex] = m/V
therefore [tex]\Delta[/tex][tex]\rho[/tex]_mercury decreases faster than [tex]\Delta[/tex][tex]\rho[/tex]_iron
and since [tex]\rho[/tex]_solid/[tex]\rho[/tex]_fluid X 100 = % of submerged solid
Therefore a greater percentage of iron will be submerged
b)
[tex]\rho[/tex]_1iron/[tex]\rho[/tex]_1mercury= 7.8 X 10^3/(13.6 X 10^3)
therefore %of submerged iron_1 = 7.8/13.6 X 100 = 57.35%
[tex]\Delta[/tex]V_iron = 1050 X 10^-6 V_1iron
V_2iron - V_1iron = 1050 X 10^-6 V_1iron
V_2iron = 1.00105 miron/[tex]\rho[/tex]_iron = 1.2834 X 10^-4 m_iron
[tex]\Delta[/tex]V_mercury = 5400 X 10 ^-6 V_1mercury
V_2mecury - V_1 mercury = 5400 X 10 ^-6 V_1mercury
V_2mercury = 1.0054 m_mercury/[tex]\rho[/tex]_mercury = 7.3926 X 10^- 5m_mercury
[tex]\rho[/tex]_1iron/[tex]\rho[/tex]_1mercury = m_iron/V_1iron/m_mercury/V_1mercury
=m_iron V_1mercury/ V_1iron m_mercury
= [STRIKE]m_iron[/STRIKE] (7.3926 X 10^-5) [STRIKE]m_mercury[/STRIKE]/((1.2834 X 10^-4)[STRIKE]m_iron m_mercury[/STRIKE]
=.5760
% of submerged iron_2 = .5760 X 100 = 57.60%
[tex]\Delta[/tex] % of submerged iron = 57.60 - 57.35 = 0.25%
I think my answer for part a) is logically sound, although there is likely an easier way to explain it. As for part b), the answer in my textbook is 0.44% not 0.25%, but I can't see where I have gone wrong. Someone please point out my mistake!
where did you get the values of beta ?
What are it's units?
Ahh, sorry.
Beta is the coefficient of volume expansion for the given substance. I got the values from a table in my textbook, and the units are: Celsius degrees^-1
FAQ: How Does Temperature Affect the Buoyancy of an Iron Cube in Mercury?
What is the relationship between temperature and buoyancy?
The relationship between temperature and buoyancy is that as temperature increases, the density of a substance decreases. This decrease in density causes an increase in buoyancy, making the substance more likely to float.
How does temperature affect the buoyancy of objects in water?
Temperature affects the buoyancy of objects in water by changing the density of the water. As the temperature increases, the density of the water decreases, making it easier for objects to float. This is why objects tend to float more easily in warmer water compared to colder water.
Can temperature changes cause changes in buoyancy without changing the mass of an object?
Yes, temperature changes can cause changes in buoyancy without changing the mass of an object. This is due to the fact that temperature affects the density of a substance, which in turn affects its buoyancy. So even if the mass of an object stays the same, a change in temperature can alter its buoyancy.
How does the temperature of air affect the buoyancy of hot air balloons?
The temperature of air plays a crucial role in the buoyancy of hot air balloons. These balloons are able to rise because the air inside them is heated, making it less dense than the surrounding air. This causes the balloon to float upwards, similar to how a helium balloon rises in air.
Can temperature changes cause changes in buoyancy in gases as well as liquids?
Yes, temperature changes can cause changes in buoyancy in both gases and liquids. This is because temperature affects the density of both gases and liquids, which in turn affects their buoyancy. For example, a hot air balloon rises due to changes in temperature, while a submarine can adjust its buoyancy by changing the temperature of the water inside its ballast tanks.
