How Does Temperature Affect the Expansion of a Rectangular Plate?
In summary: so the area would be multiplied by 4 if the length was multiplied by 2 10-6 and multiplied by 8 if the length was multiplied by 1.000002 10-6
Rblswimmer456
A rectangular plate has an area of 76 cm2.
If the temperature increases by 199 ◦C,
calculate the increase in the area. Use
2 × 10−6 (◦C)−1 as an average coefficient of
linear expansion. Ignore terms of second or-
der.
Answer in units of cm2.
I looked through my physics book and there wasn't really anything about temperature vs area and I looked online but I didn't find much so I thought I could just you use the equation:
delta(L)= (alpha)(initial L)delta(T) and I just replaced L with A..so it read...
delta(A)=(alpha)(initial A)delta(T)...and alpha being the coefficent of linear expansion
delta(A)=(2e-6)(76cm2)(199)
..and this was incorrect...any help would be appreciated to point me in the right direction...thank you!
Welcome to PF!
Hi Rblswimmer456! Welcome to PF! :smile:
(ahve a delta: ∆ and a degree: ° and try using the X2 tag just above the Reply box :wink:)
Rblswimmer456 said:
… Use
2 × 10−6 (◦C)−1 as an average coefficient of linear expansion.
"linear expansion" means that every length is multiplied by 2 10-6 per °C …
so an area is multiplied by … ? :smile:
so since its a "rectangular plate" would 2x10-6 be multiplied by 4 to get the total linear expansion?
oops!
oops! just realized my last post was wrong :redface:
(not completely awake yet! :zzz:)
should have been …
"linear expansion" means that every length is increased by 2 10-6 per °C …
so every length is multiplied by 1.000002 per °C
(did you mean "linear" ? :confused:)
no, nor the area expansion
if the length was multiplied by 2, then the area would be multiplied by 4
if the length is multiplied by 1.000002, then the area is multiplied by … ? :smile:
Your attempt at using the equation for linear expansion is correct. However, there are a few things to consider. First, make sure to convert the temperature from degrees Celsius to Kelvin (since the coefficient of linear expansion is in K^-1). So the temperature change would be 199 K.
Next, the coefficient of linear expansion is typically given in units of K^-1, not °C^-1. So you would need to convert the given value of 2 × 10^-6 (°C)^-1 to 2 × 10^-6 K^-1.
Finally, the equation you used gives the change in length, not area. To find the change in area, you can use the equation A = L x W, where L is the original length and W is the original width. So the equation would be:
delta(A) = (alpha)(initial A)(delta(T))
= (2 × 10^-6 K^-1)(76 cm^2)(199 K)
= 3.03 cm^2
Therefore, the increase in area would be 3.03 cm^2.
FAQ: How Does Temperature Affect the Expansion of a Rectangular Plate?
What is the relationship between temperature and area increase?
The relationship between temperature and area increase is a complex one. In general, as temperature increases, the area of a substance or object also tends to increase. This is because as the temperature increases, the molecules in the substance or object gain energy and move more, causing them to take up more space.
How does temperature affect the expansion of materials?
Temperature is a major factor in the expansion of materials. As temperature increases, the molecules in a material move more and take up more space, causing the material to expand. This expansion can be seen in various materials such as liquids, gases, and solids. The amount of expansion of a material is also dependent on the material's coefficient of thermal expansion.
What are some examples of temperature affecting area increase?
There are many examples of temperature affecting area increase. For instance, when water freezes and turns into ice, it expands in volume due to its molecules forming a crystalline structure. Another example is when metal objects are heated, they often expand and can cause structures or machines to malfunction.
What happens to the density of a substance as temperature increases?
As the temperature of a substance increases, its density typically decreases. This is because as the molecules move more and take up more space, they become less densely packed. This can be seen in the case of liquids and gases, where an increase in temperature leads to an increase in volume and a decrease in density.
Is there a limit to how much a substance can expand due to a temperature increase?
There is no specific limit to how much a substance can expand due to a temperature increase. However, the amount of expansion is dependent on the material's coefficient of thermal expansion and the temperature change. In extreme cases, a substance may reach its melting point or undergo a phase change before expanding further due to temperature.
