I How Does Temperature Affect Wire Tension at Constant Length?
The discussion centers on the thermodynamic description of a wire using three coordinates: tension, length, and absolute temperature. The book "Heat and Thermodynamics" states that while an equation of state typically cannot be expressed simply, Hooke's law applies under certain conditions for a wire at constant temperature. The derived equation indicates that an increase in temperature at constant length results in decreased tension, suggesting useful rates of change can be obtained even without a specific equation of state. It is clarified that to maintain constant length while heating, the wire must be initially cooled, and tension increases as the wire cools. The conversation emphasizes the practical implications of thermal expansion and tension in materials like wires and railway tracks.
zenterix
TL;DR Summary
How do we interpret the partial derivative of wire tension relative to temperature, holding wire length constant?
I have a question about a derivation I saw in the book "Heat and Thermodynamics" by Zemansky and Dittman.
A "sufficiently complete" thermodynamic description of a wire is given in terms of only three coordinates
1. tension in the wire, ##\zeta##
2. length of the wire, ##L##
3. absolute temperature, ##T##
What this means is that we have a simple thermodynamic system (defined generally as a system with three thermodynamic coordinates T, Y, Z, where T is temperature).
The book says
The states of thermodynamic equilibrium are connected by an equation of state that, as a rule, cannot be expressed by a simple equation.
For a wire at constant temperature within the limit of elasticity, however, Hooke's law holds; namely, for the tension ##\zeta## in a stretched wire.
$$\zeta=-k(L-L_0)$$
where ##k## is Hooke's constant and ##L_0## is the length at zero tension.
I was a little confused by the expression "as a rule" in the snippet above. What rule?
Now let's consider an infinitesimal change from one state of equilibrium to another.
$$dL=\left (\frac{\partial L}{\partial T}\right )_{\zeta} dT+\left (\frac{\partial T}{\partial \zeta}\right )_{T} d\zeta$$
My first question is about the assumption that we have a function ##L=L(\zeta, T)##. This is an equation of state (albeit, functionally unspecified of course).
Is the implicit equation of state the one mentioned in the snippet above that cannot be expressed by a simple equation?
There is a physical quantity called linear expansivity, defined as
$$\alpha=\frac{1}{L}\left (\frac{\partial L}{\partial T}\right )_{\zeta}$$
and another called isothermal Young's modulus, defined
$$Y=\frac{L}{A}\left (\frac{\partial\zeta}{\partial L}\right )_{T}$$
where ##A## denotes the cross section of the wire.
Now, ##\alpha## is usually positive for metals, and ##A## is always positive, according to the book. These are experimentally determined for different materials.
The derivations that follow are to obtain an expression for ##\left (\frac{\partial\zeta}{\partial T}\right )_{L}## in terms of the physical quantities above.
I will attach a screenshot of the detailed derivation, but the result is
$$\left (\frac{\partial\zeta}{\partial T}\right )_{L} = -\alpha AY$$
My second question is how to interpret this equation.
It seems to say that for an increase in temperature, keeping the length of the wire constant, the tension decreases. Is this true?
Is the point of this derivation to show that even without an explicit equation of state we can obtain useful rates of change like this?
It is not clear why the book mentioned that Hooke's law holds sometimes. Again, is it to show that even if we don't have something like Hooke's law we can make use of differential calculus to obtain useful results since we can measure the terms in the mathematical expressions we obtain?
How does one physically heat up a wire while keeping the length constant but the tension variable?
Finally, here is a screenshot of the derivation of the result shown above
You do not heat it, you cool it.
While it is hot, you lay the wire along a flat path, so it does not sag due to gravity. You remove slack from the wire, while attaching the ends to immovable objects.
If you want to heat the wire, you can run an electric current through the wire, or wait for the Sun to rise. The coldest hour will be just before dawn.
In the process you describe, as you cool the hot wire attached to immovable objects, is the tension increasing?
Yes.
Wires and railway tracks are shortest when they are cold. As they heat in the sun during the day they lengthen, so wires sag more and the expansion gaps close where train tracks join, until the track buckles under compression in the very hottest weather.
You should install the wire without slack, on a hot summer afternoon. It will then always be under tension when cooler. On a cold and clear night, the wire may shrink sufficiently to yield under tension.
If you heat a wire up at constant length, unless the temperature rise is very small, the wire is going to buckle. However, if you have a short rod constrained in length, and you heat it up, it is going to go into axial compression. The net result will be the same as if you heated it up unconstrained (so that it expanded axially), and then compressed it axially back to its original length.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
