- #36
jbriggs444
- 12,806
- 7,448
If I understand the setup properly, we have a nut and bolt suspended by a thread. The nut is made more massive by adding some mass to it. In my mind's eye, we have welded some wings onto it and balanced them nicely.Mark2020 said:Although, obvious I was waiting to be confirmed before I proceed with what I have in mind. Then, let's say we have a construction that is based on the fastener screw-nut mechanism, namely a linear actuator suspended by a strand.
We have attached a small mass (0.5 Kgr just to give more momentum) to the moving part (nut) that can be transferred from one end to the other. Based on your comment above, all those terms I used convey no actionable information.
So, when the moving part starts moving then due to the momentum conservation, the entire construction (linear actuator) will start moving in the same direction as the moving part, right?
We have some sort of self-contained motor arrangement on the pair so that we can press a button and have the nut spin itself from one end of the bolt to the other.
Now you claim that when the nut spins down the shaft to the right, that the bolt + motor also moves to the right?! That would not conserve momentum.
I begin to have grave misgivings about the prospect that we are being asked to confirm the design of a reactionless drive -- something that magically converts torque to linear impulse.
Edit: Misgivings confirmed -- and I'm out as of #55.
