How does the current carrying capacity depends on thickness
In summary, the current carrying capacity of a wire depends on the thickness of its insulation. When a wire carrying current is insulated, it is protected from outside temperature and the heat generated inside is dissipated through the insulation. However, if the insulation thickness is too thick, it will decrease the heat transfer to the surrounding and can lead to overheating. This is why insulation is important for hot water pipes in cold climates to prevent heat loss, but it can be detrimental for wires carrying high currents.
Anshul J 2016
How does the current carrying capacity depends on the thickness of insulation of conductor ?
What physical thing happens to a wire carrying current ?
When you insulate that current carrying wire, what then happens to the wire ?
and if the insulation is even thicker ?
As a side hint ... think about why insulation is put around a hot water pipe in parts of countries with cold climates ... what does that insulation achieve ?Dave
Likes Anshul J 2016
so what are your thoughts ?
can you think of some answers to those Q'sDave
First of all Thanks for those questions which are in turn helping me to ponder about the answer of my question..
My views on your questions asked are as -
1. Physical thing - Heating effect is produced in wire carrying current due to resistance..
2.When we insulate the wire, wire gets protected from outside temperature and heat generated inside the wire gets dissipated through insulation ( if insulation thickness is equal or less than critical radius.)
3. If insulation thickness is increases beyond the critical thickness than heat transfer decreases to surrounding.
4. In cold countries hot water pipes are insulated to prevent the loss of heat from water to outside where temperature is low and thus reducing the heat loss.
Anshul J 2016 said:
1. Physical thing - Heating effect is produced in wire carrying current due to resistance...
Yes
no, you are looking at it the wrong way around ... if the wire has insulation on it, the heat can't escape as easily
yes, but for any thickness
yes, so you see how that is bad for a wire carrying current
the overall effect is ... The insulation will cause the wire to heat up more, and as the temperature of the wire increases,
it's ability to carry current decreases. All very significant in circumstances where high current is a factor
you might find this an interesting read ...
http://www.ieee802.org/3/poep_study/public/sep05/walling_2_0905.pdf
cheers
Dave
Related to How does the current carrying capacity depends on thickness
1. How does the current carrying capacity change with thickness?
The current carrying capacity is directly proportional to the thickness of the material. This means that as the thickness increases, the current carrying capacity also increases, and vice versa.
2. Is there a specific formula to calculate the current carrying capacity based on thickness?
Yes, the current carrying capacity (I) can be calculated using the formula I = k * (t/d), where k is a constant, t is the thickness of the material, and d is the distance between the two conductors.
3. Does the type of material affect the current carrying capacity's dependence on thickness?
Yes, different materials have different conductivities, which can affect the current carrying capacity's dependence on thickness. Materials with higher conductivity will have a higher current carrying capacity for a given thickness.
4. How does temperature play a role in the current carrying capacity's dependence on thickness?
In general, higher temperatures can decrease the current carrying capacity, regardless of the thickness. This is because higher temperatures can increase the resistance of the material, leading to a decrease in current carrying capacity.
5. Can the current carrying capacity be increased by increasing the thickness indefinitely?
No, there is a limit to how much the current carrying capacity can be increased by increasing the thickness. This is because at a certain point, the material will reach its maximum conductivity and any further increase in thickness will not significantly affect the current carrying capacity.
  • Electromagnetism
  • DIY Projects
