B How does the doping concentration affect the depletion width?
The depletion region in a semiconductor decreases with increasing doping concentration due to enhanced recombination of charge carriers. When a junction is formed, excess electrons from the n-type material diffuse to the p-type, where they meet holes. Higher doping concentrations increase the likelihood of these electrons encountering holes, leading to a shorter recombination path. The asymmetry of the depletion region arises from differences in effective mass between electrons and holes, affecting their distribution. Understanding these dynamics involves complex mathematical concepts like distribution functions and mean free paths.
Kaushik
TL;DR Summary
In my book, it is given that the depletion width increases with a decrease in doping concentration.
I do not understand why that is the case. Is there any intuitive explanation for it? Thanks
Stating it the other way might give a better intuition: Depletion region decreases with increasing doping concentration.
The definition of the depletion region is there are no free charge carriers there. Because they are "recombined". Recombination is the process of an electron meeting with a hole and terminating each other. This is how it works:
When you make a junction the excessive electrons in the n-type is going to diffuse towards the p-type. (And vice versa.) If your doping concentration is high the probability of an electron to meet with a hole is going to be enhanced. So all the electrons diffused to the p-side are going to find their mathces in a shorter path.
The exact details are somehow mathematical involving the "distribution functions","effective masses" and "mean free paths". That is the reason that even if you get the same concentrtion of electrons and holes on both sides the depletion region will be asymetric becausse the effective mass of a hole is bigger. Hope that helps.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
