How does the doppler effect resolve the twin paradox?
In summary, the twin who stays at home sees the older twin's signals come in later than the twin who travels.
Dennydont
45
If you had twin 1 on the earth, and twin 2 fly to a star and back at a speed of v with the Earth and star separated by a distance L, twin 1 sends out flashes at intervals of t seconds (measured in his frame). Taking into consideration the numbers of redshifted and blueshifted flashes that the second twin receives, the time for T1 (twin 1) is equal to gamma*T2. How does one explain this using doppler effect?
I'm not sure if the Doppler shift explains the twin paradox, but it does illustrate the difference between the two twins.
When twin 2 blasts off, she sees the signals from twin 1 Doppler shifted lower (they arrive less often that once every t seconds). The minute she turns around, she sees the signals from twin 1 Doppler shifted higher (they arrive more often than once every t seconds).
If twin 2 sends out N signals on the way out, and N on the way back, then she sends out a total of 2N signals. Because of the Doppler shifts, she receives [itex]N \frac{\sqrt{1-\frac{v}{c}}}{\sqrt{1+\frac{v}{c}}}[/itex] signals on the way out from twin 1, and receives [itex]N \frac{\sqrt{1+\frac{v}{c}}}{\sqrt{1-\frac{v}{c}}}[/itex] on the way back. So the total number she receives from twin 1 for the whole trip is:
[itex]N \frac{\sqrt{1-\frac{v}{c}}}{\sqrt{1+\frac{v}{c}}} + N \frac{\sqrt{1+\frac{v}{c}}}{\sqrt{1-\frac{v}{c}}} = 2N \frac{1}{\sqrt{1-\frac{v^2}{c^2}}} > 2N[/itex].
So the traveling twin receives more signals than she sent, so she concludes that the stay-at-home twin aged more.
If you look at it from the point of view of the stay-at-home twin, it's not exactly the same. It's still true that he sees the signals from twin 2 Doppler-shifted lower during the outward journey, and Doppler-shifted higher during the return journey. But the difference is that the stay-at-home twin doesn't see the signals from the traveling twin until long after the traveling twin turns around. That's because, it takes time for those blue-shifted signals to reach Earth, and in that time, the traveling twin is also traveling toward Earth. So by the time the signals reach Earth, the traveling twin is almost home. So the stay-at-home twin doesn't see half red-shifted signals and half blue-shifted signals; he sees mostly red-shifted signals and then a very brief time of blue-shifted signals.
The rest of your post is the explanation; it's the same explanation that's given in the Usenet Physics FAQ article that Nugatory linked to.
Related to How does the doppler effect resolve the twin paradox?
1. What is the doppler effect?
The doppler effect is the change in frequency or wavelength of a wave as observed by an observer moving relative to the source of the wave. This phenomenon is commonly experienced with sound waves, such as the change in pitch of a siren as it approaches and then passes by a stationary observer.
2. How does the doppler effect relate to the twin paradox?
In the twin paradox, one twin travels at high speed relative to the other twin. According to the theory of relativity, time is relative and can pass at different rates for different observers. The doppler effect is used to explain how this time dilation occurs for the twin in motion, resulting in one twin experiencing less time than the other.
3. Can the doppler effect resolve the twin paradox?
Yes, the doppler effect can provide an explanation for the time dilation experienced in the twin paradox. It helps to understand and calculate the difference in time experienced by the moving twin compared to the stationary twin.
4. How do you calculate the time dilation using the doppler effect?
The formula for time dilation due to the doppler effect is given by t' = t / (1 - v/c), where t' is the observed time, t is the proper time, v is the relative velocity, and c is the speed of light. This formula can be used to calculate the difference in time experienced by the moving twin compared to the stationary twin.
5. Are there any real-life examples of the doppler effect resolving the twin paradox?
Yes, the doppler effect has been observed and confirmed in various experiments, including the Hafele-Keating experiment which involved atomic clocks on airplanes traveling at high speeds. This experiment demonstrated the time dilation predicted by the doppler effect and the theory of relativity.
