How does the hermiticity of Hamiltonian restrict its Lagrangian?
In summary: Lagrangian to be hermitian?In summary, the hermiticity of the Hamiltonian comes up as a result of requiring real energy eigenvalues and well-defined inner-product for correlation amplitudes. It is unclear why the Lagrangian should be hermitian, but it is if time evolution is unitary.
crackjack
120
The hermiticity of Hamiltonian comes up as a result of requiring real energy eigenvalues and well-defined inner-product for correlation amplitudes.
In the corresponding Lagrangian picture (path-integral), I am not clear about the explicit restriction that the above hermiticity of Hamiltonian impose on the Lagrangian. Its the basic path-integral formulation itself, in addition to the integral depending non-trivially on a special path-integral measure, exponential of Lagrangian and so on that makes it unclear. I don't see why Lagrangian should be hermitian.
Any pointer?
The Lagrangian is just the Legendre transformation of the Hamiltonian:
[tex]H = \vec q \cdot \vec p - L[/tex]
So if H, q, and p are Hermitian...then L had better be.
I allways thought that the equivalent is the invariance of the action under symplectic transformations.
@ Ben Niehoff
[tex]\vec q \cdot \vec p[/tex] is hermitian only if q and p commute, which they don't always do in quantum theory.
@DrDu
That sounds plausible. But that takes care of only unitarity, but what about the other conditions (real eigenvalues etc)?
Yes, the problem with the statement in #2 is that it refers to the classical Hamiltonian for which the term hermitian is not defined.
To my post: If time evolution is unitary, then its generator (H) is self-adjoint (Hermitian) and the eigenvalues are real: Theorem of Stone.
Whether it is sufficient for the Propagator to be unitary that the Action is symplectic, I don't know for sure, but I doubt it. Remember vaguely having read an interesting article by Zhu and Klauder, "Classical symptoms of quantum illnesses", Am J Phys (1993) vol 61, pp. 605
@ DrDu
I am also not sure about your earlier statement now.
We don't even need a symplectic manifold to define the lagrangian right?
Also, in hamiltonian mechanics, unitarity is required in symplectic transformations of the flow induced by the hamiltonian vector field. For lagrangian, which flow/transformation to take?
That article was interesting and satisfies a long-held curiosity about quirks of unbounded operators in physics.
I've heard a lot of Mathematical descriptions of what happens to the lagrangian, but they're all so complicated that I can't understand what implications it might have physically
The hamiltonian is hermitian because time evolution is unitary (these statements are equivalent --- oh, is this true in infinite dimensional vector spaces? it probably isn't).
Unitarity of Time Development means that if you have 2 distinct quantum states (orthogonal), they stay distinct after any length of time, and probability among all states is conserved. This is equivalent to Liouville's Theorem of classical mechanics, and it's an assumption of quantum mechanics.
Physically, this means that if I had a decision between 2 measurably distinct states (like |0> and |1>) and one of them was taken, after that point, the 2 states stay distinct.
I think I can understand that.
The hamiltonian being hermitian means that all eigenvalues are real and positive. Therefore, any measurable amount of the energy is is positive. I've read that this is good in classical mechanics because energy is always being radiated into the environment, which sends states into lower and lower energy states... if our energy can be negative, we'd get everything collapsing into lower and lower states, which is something we don't observe.
Therefore, when we generalize to quantum mechanics, we want the same sort of thing. We want our system to be able to stabilize and not decay forever.
I can understand this too... I think... I think I'm missing something important, but I think I almost get it.
The lagrangian measures a weighting on the path from one state to the next... Why is it hermitian? What does this mean?
And I don't think anyone actually knows this very well, so I challenge you all to give a good physical description of what it means that the Lagrangian is hermitian.
Whoops. I walked away and realized that I was completely off. The Hamiltonian being hermitian means that its eigenvalues are real and its eigenvectors are orthogonal.
I understand that the energy is the angular velocity of the phase, which governs probability. If I make the eigenvalues complex, I seem to get my system to decay immediately.. I don't understand why it's important that the eigenvectors are orthogonal though.
Perhaps I should make another post on this after I think about it for a while.
Orthogonality is naturally satisfied if the Hilbert space is separable (ie. if the vectors generating the Hilbert space are countable). The question of whether to consider an uncountable generating basis (or not) sounds more of a philosophical question.
As for the theorem, it only says self-adjointness implies reality and orthogonality - not the converse. There may be a weaker requirement than self-adjointness that makes this theorem bidirectional. Supporting this argument is the field of non-self-adjoint, but PT-symmetric, Hamiltonians that have real eigenvalues (quant-ph/0501052).
Coming back to the main question of this thread:
What condition is to be satisfied by the Lagrangian, if the Hamiltonian is to have a real spectrum (or at least, hermitian)?
Why? The commonly used position (same for momentum) basis [tex]\{\left|x\right>\}_{x\in\mathbb{R}}[/tex] is uncountable, so it seems like a very practical question?
Oh yes, you are right. But these are orthogonal as a distribution because their measures can be defined well (an extension of the basis being countable). I should then say that the question of not being countable (even as a distribution) is not very practical.
Maybe LukeD can start a new thread on this.
I just had a look at my von Neumann, "Mathematische Grundlagen der Quantenmechanik":
If the Hamiltonian (no explicit time dependence) is self-adjoint then it has a spectral decomposition [tex] H=\int_{-\infty}^{+\infty} \lambda dE(\lambda) [/tex], then the propagator can be written as [tex] U(t-t_0)=\int_\lambda exp(i\lambda (t-t0)) dE(\lambda) [/tex]. Here [tex][E(\lambda),E(\lambda')]=0, \; E(-\infty)=0; \; E(+\infty)=1; E(\lambda) E(\lambda')=E(\mathrm{min}(\lambda, \lambda')) [/tex]. That is the E form a family of projectors. E.g. if the Hamiltonian has a pure point spectrum with eigenvalues lambda, then [tex]E(\lambda)[/tex] projects on the subspace spanned by all eigenvectors with [tex]\lambda'<\lambda[/tex]. Hence E(lambda) is constant most of the time and increases at an eigenvalue. If H has also a continuous spectrum, then E increases continuously. Thus there is no need to bother about a non-countable basis of vectors |x>.
@ DrDu
Ya, that's the spectral theorem.
The countability in finite-dim cases is required so that we can do the Gram-Schmidt process explicitly. I think, in the infinite-dim case, even when the measure (in this case, dE) exists it might exist abstractly as a Lebesgue measure which does not necessarily lend itself to doing explicit processes. That is, even if we can abstractly define the spectrum as those 'x' where (A - xI)⁻¹ exists, it doesn't say anything about explicitly mapping those 'x'. Or may be I am wrong. This is too much abstractness for me.
I think the next step would be to define precisely which mathematically well defined path integral representation to use. I don't know much about this. I think, analytic continuation to Euclidean path integrals with imaginary time is an approach which can be applied rather generally. The analytic continuation of the propagator is no longer hermitian but decays exponentially. Any idea what we could learn from this?
@ DrDu
I don't get why you are rotating the time axis. Let's just stick to a real time.
Now, in deriving the path-integral from time evolution operator (involving a self-adjoint Hamiltonian), in what way is the Lagrangian restricted?
I believe, this restriction can be seen only on quantizing the path integral.
I get a feeling that the individual formulations of Lagrangian and Hamiltonian mechanics are rigorous, but the their connection is a little hand-waving.
As far as I know, the continuum version of the path integral (the one that really contains L) is ill-defined for real times. On the other hand, if you stick to a finite number of time slices, then there will be no Lagranian, only p's and q's and H's.
Time rotation is more of a calculation trick that simplifies things than anything. As long as we are not doing any explicit calculation with, let's leave time as real.
Ok, then please write down the concise formula for the path integral you want to talk about.
I was thinking we could just stick to the following original formulation without rotating time:
[tex]
\langle \phi_f | e^{-iHt} | \phi_i \rangle = \int_{\phi_i}^{\phi_f} [\mathcal{D} \phi]\ e^{i\int_0^t L\ dx^4 }
[/tex]
Has the equivalence of hamiltonian and path-integral formalism been established beyond doubt, or just established in few situations (quadratic etc) and just assumed to extend to rest?
It took 20 years to figure out how to solve the Hydrogen atom using path integrals. That was the main reason why Feynman himself did not use it as an alternative introduction to QM in his classes, if I remember correctly. I must say that I know little about the path integral, but I think the problem is that the measure [tex]D \phi [/tex] is not defined.
No one else out there who knows more?
Hm. I skimmed through Kleinert's Path Integrals book and I now think the relation between lagrangian and hamiltonian is even murkier. I doubt if the restriction on the Lagrangian, due to a hermitian Hamiltonian, can be found generically.
During the weekend I had again a look at the article by Zhu and Klauder, which I cited above. He discusses, among others, the Hamiltonian H=p with different boundary conditions. In QM, it can be a valid Hamiltonian depending on the boundary conditions. What is the corresponding Lagrangian?
FAQ: How does the hermiticity of Hamiltonian restrict its Lagrangian?
What is hermiticity of a Hamiltonian?
Hermiticity of a Hamiltonian refers to the property of a quantum mechanical operator that is self-adjoint, meaning that its eigenvectors form a complete and orthonormal basis. This property is important because it ensures that the Hamiltonian is a Hermitian operator, which means that its eigenvalues are real and its eigenvectors are orthogonal.
How does the hermiticity of a Hamiltonian affect its Lagrangian?
The hermiticity of a Hamiltonian restricts its Lagrangian in that it must be real and the Lagrangian density must be Hermitian. This is because the Hamiltonian is the operator that generates time evolution in quantum mechanics, and its Hermitian property ensures that the time evolution is unitary and the probability of finding a particle remains conserved.
What are the implications of not having a Hermitian Hamiltonian?
If a Hamiltonian is not Hermitian, then it is not a valid operator in quantum mechanics. This means that the time evolution it generates is not unitary, and the probability of finding a particle is not conserved. This violates the fundamental principles of quantum mechanics and can lead to inconsistencies and contradictions.
How is the hermiticity of a Hamiltonian related to the symmetry of a system?
The hermiticity of a Hamiltonian is closely related to the symmetry of a system. In fact, the Hamiltonian must be invariant under the same symmetries as the Lagrangian in order to be Hermitian. This is known as the Noether's theorem, which states that every continuous symmetry of a system gives rise to a conserved quantity, and in the case of quantum mechanics, this conserved quantity is related to the Hermiticity of the Hamiltonian.
Can the hermiticity of a Hamiltonian be violated?
The hermiticity of a Hamiltonian is a fundamental property in quantum mechanics and it cannot be violated. If a Hamiltonian is found to be not Hermitian, then it is not a valid operator and cannot be used to describe a quantum system. However, in certain situations, such as when dealing with open quantum systems or when including external fields, the Hamiltonian may appear to be non-Hermitian. In these cases, methods such as the use of non-Hermitian effective Hamiltonians can be employed to still describe the system accurately.
