How Does the Ideal Gas Law Apply in Multi-Part Physics Problems?
  • Thread starter barryj
In summary: State B: Pressure is increased to 3 atm...Result:T = PV/R = (1)(4)/0.0821 = 48.7 KInternal energy = (3/2)nRT
barryj
856
51
See attached diagram
See below
[/B]
Part 1) Temperature at point A.
Since P is in Atmospheres and V is in Liters R = 0.08205
Using ideal gas law, PV = nRT
T = PV/R = (1)(2)/0.080205 = 24.375 K
Part 2) As above T = (3)(2)/0.08205 = 73.125 K
Part 3) This is where I am not sure...
Delta E = (3/2)nR (deltaT) = (1.5)(0.08205)(73.125-24.375) = 6 Joules ?
Continuing...
Part 4) How much work is done from point A to point B?
Answer 0 work is done sine there is no change in volume.
Part 5) How much heat is transferred from point A to point B
Answer, it must be 6 Joules, the same as the change in internal energy.
That looks ok.
As above, I calculated the temperature at point C = 146,
and the temperature at point D = 48.6.
I am assuming that I can use either PV/T = PV/T or PV = nRT to calculate the temperatures, yes?
So here is my big concern.
The change in U from point B to C is .. E = (3/2)R (deltaT) = (1.5)(0.08205)(73) = 9 J
The work is..,W = P(deltaV) = (3)(2) = 6 J,
so the heat added must be 9 + 6 = 15 J Is this correct?
<Moderator's note: Threads merged>
1. Homework Statement
We have 1 mole of gas at P = 1 atm and V = 2 Liters
Since I am using atm and literes, R = 0.0821
So, since PV = nRT I calculate that T = PV/R = (1)(2)(0.0821) = 24.4 K
The internal energy = (3/2)nRT
In this case R = 8.315 J/(mol X K)
so E = (3/2)(8.315)(24.4) = 298 J
Lets add heat so the pressure goes to 3 atm.
Then the temperature is 73.2 K
and the internal energy = (3/2)(8.315)(73.2) = 912 J
This says that the change in internal energy is 912 - 298 = 614 J
However, this is my confusion..
I read that the change in internal energy = (3/2)nR(delta T)
Since I am using atm and liters R should be 0.0821 and this gives
(delta E) = (3/2)(0.0821)(73.2 - 23) = 6 J
I get different answers for the change in internal energy.
What is going on here? What value of R should I be using where?
I get something slightly different here.
In this case, the first equality comes from the second. The equation of state for the ideal gas is PV=nRT, and since nR is constant, so will the ratio PV/T.
The procedure is correct, but I just realized that your values for U are wrong. The gas constant you used is okay when dealing with pressure in atm and value in l, but for calculating U you need to use R = 8.314 J K-1 mol-1.
If you use R=0.0821 L atm K-1mol-1 you get the internal energy in L atm units, not in joules.
Likes Chestermiller and DrClaude
PV = nRT, T = PV/R = (1)(4)/0.0821 = 48.7
Where is the error ?
I am still confused over the calculation of internal energy and the change in internal energy.
I am using P in atm and V in Liters so R should be 0.0821, yes
But i read that the internal energy = (3/2)nRT and in this casre R = 8.315
Homework helper said that if I use R = 0.0821 the energy is in atm liter units. I do not understand.;
Let me restate the question.
State A: P = 1 atm, V = 2 liters, 1 mole, r = 0.0821
Using PV = nRT T = PV/R = (1)(2)/.0821 = 24.36 K
E = (3/2)nRT = (1.5)(8.315)(24.36) = 303.83 J
State B: P = 3 atm, V = 2 liters, 1 mole
T = PV/R = (3)(1)/0.0821 = 73.08 K
E = (3/2)(nRT = (1.5)(8.315)(73.08) = 911.49
The increase in internal energy (deltaE) = 911.49 - 303.83 = 607.66 J
Are these calculations correct?
To me, 48.6 and 48.7 are not the same. This is what I wanted to point out.
R = 8.315 J K-1 mol-1 = 0.08205 atm l K-1 mol-1
If you use the second one when multiplying by a ΔT in K, you get back an energy is units of atm l, not J.
Yes, these are the correct energies.
Referring to my initial diagram,
T = PV/R where R in this case = 0.0821
U = (3/2)RT where R = 8.315
At B: Pb = 3, Vb = 2, Tb = (3)(2)/0.0821 = 73.08 K
Ub = (3/2)(8.315)(73.08) = 911.49 J
At C: Pc = 3, Vc = 2, Tc = (3)(2)/0.0821 = 146.16 K
Uc = (3/2)(8.315)(146.16) = 1822.98
Work from B to C , W = P(deltaV) = (3)(2) = 6 J
Therefore required heat to be added , Qbc = 917.49 J
Uc = Ub + Qbc - Wbc 1822.98 = 911.49 + 917.49 - 6
Can someone confirm my numbers here? Thanks
That's not correct. If you used units throughout, you would see clearly why.
I think I get it.
3 atm = 3E5 pascals, 2 litrs = 2E-3 meters^3 so w = P*V = 3E5 X 2E-3 = 600 J Correct?
barryj said:
I think I get it.
It depends what precision you need. 1 atm = 101325 Pa, so only approximately 105.
FAQ: How Does the Ideal Gas Law Apply in Multi-Part Physics Problems?
What is a Multipart P-V problem?
A Multipart P-V problem is a type of scientific problem that involves multiple variables and their relationships to each other. It is commonly used in fields such as physics, chemistry, and engineering to model complex systems and predict their behavior.
Why is the Multipart P-V problem important?
The Multipart P-V problem allows scientists to study and understand real-world systems and make predictions about their behavior. It also helps to identify any potential issues or problems before they occur, allowing for more efficient problem-solving and decision-making.
What are the key steps to solving a Multipart P-V problem?
The key steps to solving a Multipart P-V problem include identifying all variables involved, determining their relationships to each other, setting up appropriate equations, and solving for the unknown variables. It is important to carefully consider all factors and assumptions in order to accurately solve the problem.
What are some common challenges when dealing with a Multipart P-V problem?
Some common challenges when dealing with a Multipart P-V problem include dealing with incomplete or inaccurate data, determining the appropriate equations to use, and considering all relevant variables and their relationships. It is also important to check for any potential errors or mistakes in the solution process.
How can the Multipart P-V problem be applied in real-life situations?
The Multipart P-V problem can be applied in various real-life situations, such as analyzing the behavior of gases in a chemical reaction, predicting the motion of objects in a physical system, or modeling the flow of fluids in pipes or channels. It is also commonly used in designing and optimizing engineering systems and processes.
