MHB How Does the Implicit Euler Method Affect the Amplification Factor for y' = λy?
ra_forever8
Fint the modified equation when the implicit Euler method is applied to y'= f(y). If f(y)=λy, where λ is negative. what is the effect on the amplication factor?
y ' = lambda * y
dy / dx = lambda * y
dy / y = lambda dx
ln y = lambda * x + C
y = [ C / lambda ]e^( lambda * x )
This is what I have done so far. Can anyone help me if Iam going right direction to answer the question?
y ' = lambda * y
dy / y = lambda dx
I agree with the solution up to $\displaystyle \begin{align*} \ln{|y|} = \lambda x + C \end{align*}$, from there you should get $\displaystyle \begin{align*} y = A e^{\lambda x } \end{align*}$, the constant factor does not depend on $\displaystyle \begin{align*} \lambda \end{align*}$...
y ' = λ * y
dy / dx = λ * y
dy / y = λ dx
ln y = λ* x + C
y = Ae^( λ* x ), the constant factor does not depend on λ.
i SOLVE THIS FOR THE ACTUAL SOLUTIONS
NOW,
The implicit Euler scheme is given by:
y_(n+1)= y_n +hf(y_n+1 , t_n+1 )
For f(y)=λ y, we have:
y_(n+1)= y_n +hf(y_n+1 , t_n+1 )= y_n + h λ y_n+1
Solving this for y_n+1 (in general, this is not possible), we arrive at:
y_n+1 = y_n / (1-h λ).....(eqn 1)
From (eqn 1), we can see that if |1−h λ|≥1, the solution is decaying (stable). Compare this to the actual solution of y(x)=Ae^(λ x).
If we have λ being negative, we would have:
y_n+1 = y_n / (1+h λ).....(eqn 2)
Compare this to the actual solution of y(x)=Ae^(−λ x). What conclusion can i draw?
Trying it for λ= ±1 , what happens to stability.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
