How does the moon pull on the earth?
In summary: The moon's gravity does cause the Earth to move around it, but the magnitude of that movement is given by Newton's Universal Law of Gravitation, which states that the force between two masses is proportional to the masses and inversely proportional to the square of the distance between them.
inertiaforce
60
I hope I posted this in the right section. Here are two questions I have.
1) If I pull on a very heavy object, that object's mass resists my attempt to accelerate it. This is known as inertia. When that object resists my attempt to accelerate it, it essentially pulls back on me with an equal force, correct?
2) Earth's gravity pulls on the moon. That pull accelerates the moon. The moon's mass resists that acceleration (inertia). When the moon's mass resists that acceleration with its inertia, does that cause the moon to pull back on the Earth with an equal force?
yes, and if you're pushing instead of pulling it will push back.
yes. The Earth is much more massive than the moon, so the moon's pull on the Earth doesn't move the Earth as much the Earth's pull on the moon moves the moon - that's why we can draw pictures of the moon orbiting a stationary earth. But in fact the Earth and the moon are both orbiting around their common center of gravity.
So the moon pulls on the Earth with an equal force from its inertia? I thought the moon pulled on the Earth with an equal force from its gravity?
inertiaforce said:
So the moon pulls on the Earth with an equal force with its inertia?
The Earth pulls on the moon and the moon pulls on the earth; the magnitude of both forces is given by Newton's ##F=GM_eM_m/r^2## where ##M_e## is the mass of the earth, ##M_m## is the mass of the moon, and ##r## is the distance between them. The mass (and hence inertia) of both bodies appears in this equation and cannot be separated, so it's best to think of the force between them as coming from both masses.
Yes I am familiar with that equation. Thanks for your answer.
Imagine two masses, m1 and m2. If m1 accelerates m2, m2's inertia resists the acceleration. This resistance to acceleration by m2 pulls back on m1 with an equal magnitude. When it pulls back with an equal magnitude, it becomes a force that is acting on m1. So now m2 is pulling on m1 with an equal force. if m2 is now pulling on m1 with an equal force, that equal force is now acting as though it is m2's gravity isn't it? There is an equal force between m1 and m2 at this point. That is what we define as gravity isn't it?
Newton's Third Law of Motion.
Newton's Universal Law of Gravitation describes the forces - and allows us to calculate them (via Newton's Second Law of Motion); the Third Law of Motion still applies to the result, as all force laws must be consistent with it.
The cause-effect-chain you are building here is not what Newtons 3rd says. Both forces act simultaneously. You cannot say which causes which. The common terminology of "action & reaction" is very misleading here.
Any object resists, even the tiniest. If it has mass, it has inertia.
I don't see the point of introducing the term "inertia" into this explanation. It is a rather wooly term (you won't find it defined in many textbooks) and doesn't come with a special Unit or a value, when you are dealing with simple classical mechanics.
You can discuss this sort of situation with
1)Gravitational Force = GM1M2/d2
2)Force = Mass times Acceleration
and
3)Centripetal Force = Mv2/r
which don't involve Inertia, yet they give you the answer to what will happen in Orbits - and in most other situations we have to deal with.
Add in Newton's 3rd law and you can predict what will happen with two masses orbiting round each other. The cm of the Earth Moon system is way below the surface of the Earth and the effect of the orbit of each body around this point is to give the Earth a monthly 'wobble', as the Moon 'goes round' it.
[Edit: But the terms 'inertia' is absolutely fine - inspired, even - for your name! :smile:]
Related to How does the moon pull on the earth?
1. How does the moon's gravity affect the tides on Earth?
The moon's gravity pulls on the Earth's oceans, causing a bulge on the side of the Earth that is facing the moon. As the Earth rotates, this bulge creates high tides. On the opposite side of the Earth, there is also a bulge due to the moon's pull, causing another high tide. The areas in between experience low tides.
2. Why does the moon have a greater effect on the tides than the sun?
Although the sun has a larger mass than the moon, it is much farther away from the Earth. This distance weakens the sun's gravitational pull, making the moon's pull on the Earth's oceans more significant. Additionally, the moon's orbit around the Earth is much closer and more elliptical than the sun's orbit around the Earth, further strengthening its gravitational pull.
3. How does the moon's position affect the strength of its pull on the Earth?
The moon's gravitational pull on the Earth is strongest when it is closest to the Earth, known as perigee, and weakest when it is farthest from the Earth, known as apogee. This is because the closer the moon is to the Earth, the stronger its gravitational force.
4. Can the moon's pull on the Earth impact the Earth's rotation?
The moon's gravity does exert a force on the Earth, but it is not strong enough to significantly affect the Earth's rotation. However, the Earth's rotation does impact the tides, causing them to occur at slightly different times each day.
5. How does the moon's gravitational pull on the Earth affect the Earth's orbit?
While the moon's gravitational pull does have some effect on the Earth's orbit, it is relatively small. The Earth's orbit is primarily affected by the gravitational pull of the sun. However, the moon's gravitational pull does cause small changes in the Earth's orbit, known as lunar perturbations, which can impact the timing and intensity of eclipses.
  • Science Fiction and Fantasy Media
  • Astronomy and Astrophysics
  • Other Physics Topics
  • Classical Physics
