How does the speed of light change when it enters glass?
In summary, the conversation discusses the concept of light slowing down in glass and the different velocities associated with it, including phase velocity, group velocity, and the velocity of individual photons. References are provided for further understanding, and the difference between phase and group velocity is explained. The conversation also briefly mentions the Kelvin Wedge as an example of the difference between the two velocities.
richengle
its has been said that light slows down in glass, but some talk about phase velocity and group velocity... then there is the velocity of the photons, which some say is always c.
What are those speeds [Vgroup, Vphase, Vphoton, Vlight] in glass, and what do they mean?
Science news on Phys.org
richengle said:
Summary:: light is said to slow down when it enters glass, but some say no. some say the photons travel at c, but the light wave propagates at 1/sqrt(ue). what are the velocities?
Just to place your question in context so that it can be answered more to the point, can you provide references for all these "somes" that "say" all of that?
  • Haha
Likes vanhees71 and jedishrfu
Sixty Symbols has a nice pair of explanations in this YouTube video:
jedishrfu said:
MinutePhysics explains it well:
Nope. This would be like diffuse transmission. It's just not an "atom-by-atom" process. It's the effect of all atoms collectively.
yeah, but then if, as below stated 60 sec video, this is not acurate, then what are the real velocities?
here is the second video of the series;;;
I have no idea what "they" mean.
Basically there is phase velocity and group velocity, although some may give them other names. The easy way to sort these out is that phase velocity is the propagation velocity of individual photons, and group velocity is the propagation velocity of a bunch of photons in some arrangement, like a pulse of light. The actual calculations are difficult.
https://en.wikipedia.org/wiki/Group_velocity
One should leave photons completely out of any discussion of phase or group velocity. The terms are perfectly applicable to classical waves and should be understood in that context.
The Wiki article that you reference does not use the term photon at all.
The phase velocity is the velocity of a particular point on a wave. For instance, a peak or a trough. The term "phase" is used because a peak or a trough is an example of a "phase".
The group velocity is the velocity of a group of waves moving together, hence the name. The group velocity and the phase velocity can differ because the group may evolve over time with trailing waves increasing in amplitude while leading waves fade away. In such a case, the phase velocity will exceed the group velocity. The group will lag behind.
If you look carefully at the bow wave of a ship or boat you can witness the difference in the two velocities first hand. You can see that the wave fronts defined by a particular phase within the bow wave are diagonal to the front defined by the leading edge of the disturbance that is the bow wave.
Sadly, a quick trip to Google did not bring up any good images of this.
Likes DaveE, vanhees71 and sophiecentaur
Do you mean the Kelvin Wedge?
Likes jbriggs444 and vanhees71
You mean like this?
"The red square moves with the phase velocity, and the green circles propagate with the group velocity."
Likes DaveE, DrStupid, vanhees71 and 1 other person
Not what I had in mind., @A.T. But quite a bit better. Directly on point.
Likes vanhees71
FAQ: How does the speed of light change when it enters glass?
The speed of light decreases when it enters glass.
Why does the speed of light change when it enters glass?
This is due to the difference in the refractive index of glass compared to air. The refractive index is a measure of how much a material slows down the speed of light.
How much does the speed of light change when it enters glass?
The exact change in speed depends on the type of glass and the wavelength of light. Generally, the speed of light in glass is about two thirds of the speed of light in a vacuum.
Does the speed of light change in all types of glass?
Yes, the speed of light changes in all types of glass, but the amount of change may vary depending on the composition and density of the glass.
How does the speed of light in glass compare to other materials?
The speed of light in glass is slower than the speed of light in a vacuum, but it is faster than the speed of light in other materials such as water or diamond. This is because the refractive index of glass is lower than that of water or diamond.
11K
