How does the strength of an electric field relate to its direction?
Negative charges generate electric fields directed inward, while positive charges create fields directed outward. The direction of the electric field at a point indicates the force on a positive unit charge placed there. The strength of the electric field is related to the density of field lines; closer lines indicate stronger fields. For a single point charge, the field direction remains consistent regardless of charge magnitude, only influenced by the charge's sign. Therefore, the relationship between electric field strength and direction is determined by both the charge distribution and the proximity to the charge.
samcoelho
I understand that negative charges create electric fields pointing inwards, and positive charges create electric fields pointing outwards, but what does this have to do with field stength? What is the relationship between field strength (flux?) and direction?
Field direction at a particular point is the direction of the force on a positive unit charge located at that point. If there is a charge distribution that creates the field at that point, the relative magnitudes of the charges in that charge distribution will determine the direction of the field. If the electric field is from a single point charge, the direction of the field will not be affected by the magnitude of the charge - only the sign (positive or negative). The direction will be radial from the centre of the charge.
AM
If you draw the field lines in the vicinity of one of these charged particles you will notice that the lines are closer together nearer the charged particle. These are places where the field strength is greater.
  • · Replies 41 ·
  • · Replies 73 ·
  • · Replies 21 ·
  • · Replies 17 ·
