How does thermal stress affect the length of a constrained rod?
In summary, thermal stress affects the length of a constrained rod by causing it to expand or contract in response to temperature changes. When a rod is constrained, it cannot freely expand, leading to the development of internal stresses. If the temperature increases, the rod tends to lengthen, but the constraints prevent this, resulting in compressive stress. Conversely, if the temperature decreases, the rod contracts, which can induce tensile stress. The extent of these stresses and the resulting deformation depend on the material properties of the rod, the magnitude of the temperature change, and the constraints applied.
Physicsnb
In a lecture of thermal stress my professor defined thermal strain as ' L α ΔT/ L = α ΔT ' [since strain= ΔL/L and ΔL after application of heat is L α ΔT].
He said that on a constrained body that's not allowed to expand , a force is applied on the body .
If the constraints were removed then the new length would be equal to ' L+ L α ΔT '
However while deriving the formula for thermal strain he used the length 'L' as original length .
My question is : "Shouldn't L(new) be used to derive the equation instead of length L , since the rod is compressed from this length by the walls/constraints not length L. "
ΔL= L α ΔT
ΔL = Change in length of the body
L= Original Length of the body
α= Thermal Coefficient og linear expansion
ΔT=Change in temperature
New length after change in temp, L(new) = L+L α ΔT
My attempt at deriving the equation:
Let a temperature a rod of length L constrained by walls on both ends be changed by ΔT.
So the change in lenghth of rod under no constraints = L α ΔT
Length of rod after change in temperature without walls =L+L α ΔT= L(1+L α ΔT)
However with constraints the rod is forced to length L
Then,
Thermal strain = ΔL/L(1+L α ΔT)
Thermal strain= L α ΔT/L(1+L α ΔT) = α ΔT/(1+L α ΔT)
Physicsnb said:
Homework Statement: In a lecture of thermal stress my professor defined thermal strain as ' L α ΔT/ L = α ΔT ' [since strain= ΔL/L and ΔL after application of heat is L α ΔT].
Relevant Equations: ΔL= L α ΔT
Then,
It's a first order approximation to the differential equation (1) about ## L = L_o##:
$$ \frac{dL}{dT} = \alpha L \tag{1}$$
So we say that since ##L \gg \Delta L ##
$$ L \approx L_o + \left. \frac{dL}{dT}\right|_{L_o} \Delta T $$
$$ L \approx L_o + \alpha L_o \Delta T = L_o \left( 1 + \alpha \Delta T \right) $$
At the far right of the second line above, the ##L## inside the parentheses should not be there.
Then,
OK, except for the ##L## inside the parentheses. So, your derivation gives for the thermal strain $$\text{Thermal strain} = \alpha \Delta T/(1+\alpha \Delta T)$$
Generally, ##\alpha \Delta T## is small compared to 1. In that case, the ##\alpha \Delta T## can be neglected in the denominator. So, to a good approximation $$\text{Thermal strain} = \alpha \Delta T$$ which is the same as what your professor gets. But, I think it's good to think about it the way you did.
Likes Lnewqban
Whats L_o? Also , my question was that why is strain =α Δ T .
Also can you please elaborate your derivation a bit more (specifically the second step)
TSny said:
At the far right of the second line above, the ##L## inside the parentheses should not be there.OK, except for the ##L## inside the parentheses. So, your derivation gives for the thermal strain $$\text{Thermal strain} = \alpha \Delta T/(1+\alpha \Delta T)$$
Thanks for your explanation .
α
Δ T .
##L_o## is the initial length of the body.
The strain is ## \epsilon = \frac{ \Delta L}{ L_o}##
$$ \epsilon = \frac{L - L_o}{L_o} = \frac{L_o( 1 + \alpha \Delta T ) - L_o}{ L_o} = \alpha \Delta T $$
So ,
What's L here? New length?
Physicsnb said:
So ,
It's the length of the freely expanded body when thermal equilibrium has been reached.
Could you please elaborate how you got to second step?
Could you please explain how you got to the send equation?
It's a first order Taylor Expansion about the fixed length ##L_o##. A Taylor Expansion is an approximation of a function about a given point over some interval.
That second step is the length function (which would be found by integrating (1) ) truncated to the linear terms of the expansion.
So the first term is what we expect with no change in temp. Its just ##L_o##. Then we extend it by saying over some change in temp## \Delta T##, that ##L## approximately changes like the ## \frac{dL}{dT}|_{L_o} \Delta T = \alpha L_o \Delta T ##
Likes Physicsnb
You are working with small (linearized) strain theory. At this level of approximation, ##\alpha \Delta T## is negligible compared to unity. So the thermal strain is ##\alpha \Delta T## and the superimposed compressive strain is ##\sigma /E##, where E is Young's modulus and ##\sigma## is the compressive stress..
Likes Physicsnb
FAQ: How does thermal stress affect the length of a constrained rod?
What is thermal stress?
Thermal stress is the stress that develops within a material when it undergoes a change in temperature. This stress arises because different parts of the material may expand or contract at different rates, especially when the material is constrained and cannot freely expand or contract.
How does thermal expansion relate to thermal stress in a constrained rod?
When a rod is constrained and subjected to a temperature change, it cannot freely expand or contract. This restriction leads to the development of thermal stress. The thermal expansion coefficient of the material determines how much the rod would expand or contract if it were free to do so. The inability to change length results in stress within the material.
What is the formula to calculate thermal stress in a constrained rod?
The thermal stress (σ) in a constrained rod can be calculated using the formula: σ = E * α * ΔT, where E is the Young's modulus of the material, α is the coefficient of thermal expansion, and ΔT is the change in temperature.
Does the material of the rod affect the thermal stress experienced?
Yes, the material of the rod significantly affects the thermal stress experienced. Different materials have different coefficients of thermal expansion and Young's moduli. These properties determine how much stress will develop for a given temperature change.
Can thermal stress cause permanent deformation in a constrained rod?
Yes, if the thermal stress exceeds the yield strength of the material, it can cause permanent deformation. This means that the rod will not return to its original shape once the temperature returns to its initial value. If the thermal stress is within the elastic limit of the material, the rod will return to its original shape once the temperature change is reversed.
