How does time add up to 1 second with infinite smaller amounts of time?
  • I
  • Thread starter Gondur
  • Tags
    Time
In summary, the conversation discusses the concept of time and how it can be divided into infinitely smaller amounts, leading to the question of how time moves forward. This is related to Zeno's paradox, which applies to both time and distance. The conversation also mentions the potential quantization of time and the subjectivity of our perception of it. Finally, the conversation explores the idea of infinity and its relationship to mathematical operations.
Gondur
25
Hello.
I have a question.
Time can be divided into smaller amounts of time.
So, 1 second can be divided into 1/2, 1/4, 1/6 etc seconds
SO, 1 second can be divided into 1 / infinite amount seconds
So, it follows that this will yield an infinitely small amount of time.
So, given that there is an infinite amount of 1/ infinite seconds that make up one second.
How does time go from 1 second to another because surely 1 second will never be reached?
I think this would display as an asymptotic curve - when the curve (time) never actually crosses the axis, but always tends towards it?
Do you understand my question?
Thank you.
Gondur said:
Hello.
I have a question.
How does time go from 1 second to another?
Thank you.
https://en.wikipedia.org/wiki/Zeno's_paradoxes
Likes russ_watters and CWatters
phinds said:
Yes that's what I thought, but he applied it to distance.
I apply it to time.
So, how does time go forward?
Surely since the creation of the universe till now, not one second has passed - we are still living in a time of 1/X amount of seconds?
Irrelevant. It's the exact same principle.
Gondur said:
Hello.
I have a question.
Thank you.
Whether there is a smallest possible amount of time isn't clear, yet, as far as I know. But this isn't important here. What is important is, that you treat this like ##\dfrac{1}{\infty} = 0## which doesn't make sense. The limit process doesn't apply, because you can always only calculate with a finite amount. So what's left is the so called Zeno's paradox. There are many versions of it, e.g. https://en.wikipedia.org/wiki/Zeno's_paradoxes#Achilles_and_the_tortoise
At one second per second.
Likes russ_watters
Infinity times 1/infinity = 1
Likes russ_watters
Without a human to define it there is no such thing as a second. So Seconds and fractions of a second etc are not a fundamental property of the universe.
We don't actually know if time moves in little steps (eg is quantized) or if it just rolls along smoothly (continuous)..
https://www.scientificamerican.com/article/is-time-quantized-in-othe/
Likes jerromyjon
CWatters said:
From that link:
"One could, however, ask the question in a slightly different way. By putting together G (Newton's constant of gravity), h (Planck's constant) and c (the velocity of light), one can derive a minimum meaningful amount of time, about 10-44 second."
jerromyjon said:
From that link:
But there is no indication at all that this would in any sense be a MINIMUM possible amount of time any more than the Planck length is a minimum possible length.
So should we assume tgat time is subjective and not a fundamental physical quantity?
The key word was minimum MEANINGFUL amount of time, which seems to me to address our macroscopic view of things, but there must still be smaller divisible portions to address subatomic physical time scales... or I may be wrong and Planck time is in the magnitude of subatomic processes. Either way it still is not a known quantifiable parameter.
No, our PERCEPTION of time is subjective. Local time, as measured by a valid clock, doesn't care what we think of it it just moves along and one second per second.
Likes gianeshwar
It can not.
We are inside the box named as universe. Our perception of time is perception of counting events. Even theoreticaly, if there is no events time is frozen for us. Of course if you can look outside the box, this may not be true, but we are in the box, so we can not say that.
I apply it to time.
It is still Zeno’s paradox. Both time and distance are represented by real numbers (continuum). Zeno’s paradox and its solution work for any continuum.
Likes CWatters
That is not right - it is undefined. Any attempt to treat infinity as a number that can be subjected to arithmetic operations to yield meaningful finite results will lead quickly to unpleasant contradictions.
Further discussion of this digression should happen over in the "General Math" subforum.
In order for the math to work, they MUST add up to 1 second:
1/2+1/2=1
1/3+1/3+1/3=1
Etc.
Likes jerromyjon
FAQ: How does time add up to 1 second with infinite smaller amounts of time?
How does time move forward?
Time is a concept that measures the duration of events and the intervals between them. As we experience it, time moves forward in a linear fashion, from past to present to future. This is known as the arrow of time.
Why does time only move forward?
This is still a topic of debate among scientists. One theory is that the direction of time is related to the increasing entropy, or disorder, of the universe. Another theory is that time only moves forward because we perceive it that way.
Can time ever go backwards?
While it is theoretically possible for time to move backwards, it is not currently observed in nature. Some scientists believe that time may have moved backwards in the very early stages of the universe, but this is still a topic of research and debate.
What is the role of gravity in the passage of time?
Einstein's theory of general relativity states that gravity is not a force between masses, but rather a curvature of space and time caused by the presence of massive objects. This means that the presence of mass can affect the passage of time, causing it to move slower in more intense gravitational fields.
How does time dilation affect the passage of time?
Time dilation is a phenomenon predicted by Einstein's theory of relativity, where time slows down for an observer in motion relative to another observer. This means that the passage of time can be different for two individuals moving at different speeds, but it is imperceptible in our daily lives.
