How does time behave in overlapping gravitational fields?
In summary: For example, a scientist living in some sort of temperature/pressure-resistant sphere set exactly at the Earth's center, maybe. Being weightless, he might assume the sphere to be in empty space with no gravitational field, but could he perform an experiment to find out that's not the case?
Micheth
79
That is to say, how does time behave in a region of space where multiple gravitational fields cancel out their accelerating effects?
I understand that time "slows down" in a gravitational field, but does this depend on the actual presence of the field, or instead the actual net acceleration caused by different fields? The most simple example of this case might be placing a "clock" at the center of a massive body such as the Earth, where I suppose you have no net acceleration, since it is being equally accelerated outward in all directions. So, in such a case, is time still going to be dilated, or would time flow be at the same "rate" as that of a body in empty space with no acceleration?
(If the latter is true, I imagine time dilation being maximum at the surface of the massive body, and gradually reducing to zero toward the center. If not, I imagine it gradually increasing from the surface toward some maximum at the center. Which would be the actual case?)
Likes ISamson
Time dilation depends on the gravitational potential, not the acceleration. You can just add gravitational potentials (they are scalars, not vectors, and are always negative so never cancel - always reinforce) as long as you don't get too close to a black hole. So clocks at the centre the Earth will run slow compared to ones at the surface, even though they would be weightless.
Yeah, like Einstein said that time on the top of a skyscraper runs slower than on the ground. So it is true that time would be very slow nearer the centre of the Earth.
The effect is still tiny for something as small as the Earth. Just slightly less tiny at the core than the surface...
Also, the time on top of the skyscraper runs faster than on the ground.
Likes Ibix
Thank you.
For me that (grav. fields not canceling out but net accleration being zero) is kind of counterintuitive, but that's the way it goes I guess.
Kind of a weird thought experiment, but if a sentient entity were somehow living in a void at the center of the Earth (somehow not destroyed by the pressure and heat), while realizing that it was weightless, would it still be able to determine it was being affected by different gravitational potentials?
(Subsequent edit:
For example, a scientist living in some sort of temperature/pressure-resistant sphere set exactly at the Earth's center, maybe. Being weightless, he might assume the sphere to be in empty space with no gravitational field, but could he perform an experiment to find out that's not the case?)
Yes.
Not easily. Time dilation just means that different clocks run at different rates, so you'd need to be able to see a clock out in space to observe that the rates are different.
That said, I think modern atomic clocks are precise enough to see time dilation between a clock on the floor and one on a desk. So you could compare a clock at the centre of the space and a clock at the edge and detect a rate difference. Since the whole volume is in zero gravity, I can't say if that would be enough to lead to a full theory of gravity, but it would be a clue that something was up (no pun intended).
Likes ISamson
All points are at the same potential in that center of Earth lab, so all clocks run at the same rate in the lab.
Likes Ibix
D'oh! Correct, assuming it's a spherical hollow. I think potential can vary for hollows of other shapes. For example, if they drill into the walls, they'll start to notice time dilation and a force pushing objects back towards the hollow.
Related to How does time behave in overlapping gravitational fields?
1. How does time dilation change in overlapping gravitational fields?
In overlapping gravitational fields, time dilation is affected by the combined gravitational forces acting on an object. This means that the closer an object is to a stronger gravitational field, the slower time will pass for that object compared to an object in a weaker gravitational field. This is known as gravitational time dilation.
2. Can time flow backwards in overlapping gravitational fields?
No, time cannot flow backwards in overlapping gravitational fields. Time always moves forward, but the rate at which it moves can be affected by the strength of the gravitational fields. However, in extreme cases such as near a black hole, time may appear to slow down to an outside observer, but it still moves forward.
3. How does the curvature of spacetime affect time in overlapping gravitational fields?
The curvature of spacetime, caused by the presence of massive objects, affects the flow of time in overlapping gravitational fields. The more massive an object is, the greater its gravitational pull and the more it will curve the spacetime around it. This curvature then affects the rate at which time passes in that region.
4. Can time be measured accurately in overlapping gravitational fields?
It is difficult to measure time accurately in overlapping gravitational fields because the rate at which time flows becomes distorted. However, with precise instruments and calculations, scientists can account for this distortion and still measure time with a high degree of accuracy.
5. Does time behave differently in overlapping gravitational fields compared to a single gravitational field?
Yes, time behaves differently in overlapping gravitational fields compared to a single gravitational field. In a single gravitational field, time dilation is only affected by the strength of that one gravitational field. In overlapping gravitational fields, time dilation is affected by the combined forces of multiple gravitational fields, making the effects more complex and variable.
