How Does Time Dilation Affect Space Travel Duration?
In summary: The time dilation formula is$$t_0 = \gamma t$$so if ##t_0 = 10.1##, as you found, then ##t = 10.1/\gamma##. In summary, When calculating the time it takes for a spaceship to travel from Earth to another star 10 light years away at a speed of 0.99c, it is important to clearly identify the key spacetime events and use the Lorentz transformations or the invariance of the spacetime interval to calculate the elapsed time in the frame of the spaceship. Using the classical time dilation formula may lead to errors if not applied correctly.
Arman777
Insights Author
193
TL;DR Summary
time dilation
Let us suppose a spaceship moving from Earth to another star that is 10ly away with a speed of 0.99c.
Calculate the of years spaceship takes to reach its destination (a) in the rest frame of an observer on Earth and (b) as perceived by a passenger on board the ship
For (a) I find that ##t_0 = x/v## which is 10.1 years. However for part (b) I am finding t as 71.6 years. However it seems wrong to me. Is it true or not ?
(a) is correct. (b) is wrong. How did you go about it?
I used the classical equation $$t = \frac{t_0} {(1 - (v/c)^2)^{1/2}}$$. However I guess I put the time values in different places. But putting t = 10.1 year does not make sense somehow. Whats the reason behind that ?
Arman777 said:
I used the classical equation...
That’s not the right formula - you left out a reciprocal somewhere, effectively multiplying by ##\gamma## when you should be dividing.
However, the best thing to do is to forget about the time dilation formula for now and instead use the Lorentz transformations:
The two relevant events are “ship leaves earth” and “ship arrives at destination”.
When we use the frame in which the Earth is at rest to assign coordinates to these events we get ##(t=0,x=0)## for the “leaves” event and ##(t=10.1,x=10)## for the “arrives” event. The difference between the times is ##10.1-0=10.1## so that’s how many years the trip takes using that frame in which the Earth is at rest.
Now use the Lorentz transformations to find the coordinates assigned to these two events using the frame in which the ship is at rest (if you do it right, the x coordinate will be zero at both events). The difference between the t coordinates will be the elapsed time using that frame in which the ship is at rest.
And then look at what you’ve just done - you’ve derived the time dilation formula from first principles! (At least if you don’t plug in the actual numerical values until you’re done with the algebra).
Likes George Jones, Arman777 and Dale
I also favor this approach for this very reason. The time dilation formula automatically appears whenever it is valid, and you avoid errors due to incorrectly using it when it doesn’t apply.
Using the lorentz transformation is actually good idea. I understand it I guess. Thanks
Likes Dale
Like @Nugatory and @Dale, I prefer Lorentz transformations over a rote application of the time dilation formula, which I find too easy to screw up. I also like a method that uses invariance of the spacetime interval, which I think is the key concept in relativity.
In these methods, the first thing to do is to identify the key events. In this case, key event 1 is the coincidence of the spaceship and the Earth, and key event 2 is the coincidence of the spaceship and the star.
I think that a lot of students' problem are caused by failure to identify clearly spacetime key spacetime events for a particular problem.
There are two frames of reference - the frame of reference in which the Earth is at rest, and the frame of reference of the spaceship. Arbitrarily label one of the frames as unprimed and one as primed - it doesn't matter which is which. In what follows, I label the Earth's frame as the unprimed frame, and the spaceship's frame as the primed frame.
In the Earth's frame, the spatial distance between the two key events is ##\Delta x =10##, and the elapsed time in the Earth's between the events is ##\Delta t = \Delta x/v##, as in a).
In the spaceship's's frame, the spatial distance between the two key events is ##\Delta x' = 0##, since the spaceship is coincident with both events, and the spaceship doesn't move in its own frame. The elapsed time In the spaceship's's frame between the events is ##\Delta t'##.
Invariance of the spacetime interval, a fundamental property of spacetime, gives
$$\left( \Delta x \right)^2 - \left( \Delta t \right)^2 = \left( \Delta x' \right)^2 - \left( \Delta t' \right)^2 .$$
From the above, the elapsed time in the spaceship's frame is
$$ \begin{align}
\left( \Delta t' \right)^2 &= \left( \Delta x' \right)^2 - \left( \Delta x \right)^2 + \left( \Delta t \right)^2 \nonumber \\
&= 0^2 - \left( \Delta x \right)^2 + \left( \Delta x/v \right)^2 \nonumber \\
&=\left( \Delta x \right)^2 \left( \frac{1}{v^2} - 1 \right) \nonumber .
\end{align}$$
Likes Dale and Arman777
I see you've got to the answer, and I too recommend using the Lorentz transforms until you know when you can get away with using special cases like time dilation.
Nevertheless, you could have used it here. You just had the ##t## and ##t_0## the wrong way round (either in the formula or in your interpretation of which was associated with which clock).
Related to How Does Time Dilation Affect Space Travel Duration?
What is the concept of "Journey Time: Earth Observer vs. Spaceship Passenger"?
The concept of "Journey Time: Earth Observer vs. Spaceship Passenger" refers to the difference in time experienced by someone observing a journey from Earth and someone on a spaceship traveling at high speeds. This is due to the effects of time dilation, where time moves slower for objects in motion.
What causes the difference in journey time between an Earth observer and a spaceship passenger?
The difference in journey time is caused by time dilation, which is a phenomenon predicted by Einstein's theory of relativity. As an object moves at high speeds, time moves slower for that object compared to a stationary observer. This is due to the relationship between time and space, where the faster an object moves through space, the slower time moves for that object.
How does time dilation affect the length of a journey for a spaceship passenger?
For a spaceship passenger, time dilation can significantly affect the length of their journey. As they travel at high speeds, time moves slower for them, so a journey that may take years for an Earth observer would feel much shorter for the passenger. This is because the passenger's time is passing slower, so they experience less time during the journey.
Is time dilation a real phenomenon?
Yes, time dilation is a real phenomenon that has been proven through experiments and observations. It is a fundamental aspect of Einstein's theory of relativity, which has been extensively tested and verified by scientists. Time dilation has also been observed in various scenarios, such as with atomic clocks on airplanes and with particles traveling at high speeds in particle accelerators.
Can time dilation be reversed?
No, time dilation cannot be reversed. It is a natural consequence of the relationship between time and space, and it is not possible to manipulate time in this way. However, time dilation can be counteracted by traveling at extremely high speeds in the opposite direction, which would cause time to speed up for the object in motion. This is known as time contraction.
