How Does Total Energy Relate to Potential Energy in a Closed System?
In summary: So when E < max(PE), then K < max(PE) and so K + PE = constant. The point where E = PE is called the turning point where the object reverses direction.In summary, when the total energy of a system is less than the maximum potential energy, it must equal to some potential energy in a potential energy diagram. This is because the total energy is constant and the maximum amount of kinetic energy is dependent on the potential energy, so it cannot exceed it. This results in the point of intersection between the total energy and potential energy being the turning point where the object reverses direction.
Mathematicsresear
66
Why is it that when the total energy of a system less than the max potential energy, it must equal to some potential energy in a potential energy diagram.
Total energy intersects multiple points in U(x) diagram. However, since potential energy is increasing before max U(x), and E< maxU(x), couldn't it be equal to some kinetic energy as well? However how I do know that that is the case? Why can't kinetic energy be greater at that point?
E = K + U
E = constant which means K + U = constant
When E = U at the point of intersection, then U = K + U which means K = 0.
In short, if K + U = constant, then it follows that at the point of intersection K = 0. BTW, point xT such that U(xT) = E is the classical turning point where the particle reaches zero speed and reverses direction.
If the system is "closed" (no energy gets in or out) then the total energy is constant. So the maximum amount of KE depends on the PE. The KE can't be arbitrarily high.
Related to How Does Total Energy Relate to Potential Energy in a Closed System?
1. What is the total energy of a system?
The total energy of a system is the sum of all the different types of energy present in that system. This includes kinetic energy, potential energy, thermal energy, chemical energy, and other forms of energy.
2. How is the total energy of a system calculated?
The total energy of a system can be calculated by adding up the individual energies of all the components in the system. This can be done through mathematical equations or by measuring the energy directly.
3. Why is it important to understand the total energy of a system?
Understanding the total energy of a system is crucial in many scientific fields, such as physics, chemistry, and engineering. It allows us to analyze and predict the behavior and interactions of different components within a system.
4. Can the total energy of a system change?
Yes, the total energy of a system can change if energy is added or removed from the system. This can occur through various processes such as energy transfer, conversion, or dissipation.
5. How does the total energy of a system relate to the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, only transferred or converted from one form to another. The total energy of a system remains constant, even if it changes form, in accordance with this law.
