How does wireless power transfer produce magnetic flux?
In summary, the conversation discusses the relationship between magnetic flux and wireless power transfer. It is noted that for an electric current to be induced in a wire, there must be a changing magnetic flux. This is demonstrated through videos on YouTube showing wireless power transfer to a lightbulb or LED, where the light appears constant but is actually flickering at the frequency of the AC. This is due to the alternation of the magnetic flux, which is also responsible for power transfer in other wireless links.
Thundagere
159
From what I learned, for an electric current to be induced in a wire, there must be a magnetic flux. On youtube, there are lots of videos showing wireless power transfer to a lightbulb or LED. However, the light is constant. How is the magnetic flux changing in such a setup?
The flux must be changing in time (alternating) for any sustained induction to take place.
When you turn on the AC mains supply to a light bulb, the light appears constant whereas it is actually flickering (to some extent) at the rate of the AC. Power is transferred 'wirelessly' even for mains AC, whenever transformers are used. There is no actual 'wire' connection between primary and secondary windings. The transfer of power is due to the alternation of the magnetic flux. This is the same for wireless links which operate at higher frequencies and the perception of any flickering is much reduced by the circuitry and also by the response our eyes' photo-receptors. For wireless power transfer over a long distance, the electric field variation also counts.
Related to How does wireless power transfer produce magnetic flux?
1. How does wireless power transfer work?
Wireless power transfer uses electromagnetic induction to transfer energy from a power source to a receiving device without the need for physical wires. This is achieved by creating a magnetic field with an alternating current in a transmitting coil, which induces a current in a receiving coil.
2. What is the role of magnetic flux in wireless power transfer?
Magnetic flux is a measure of the strength of the magnetic field being produced by the transmitting coil. In wireless power transfer, the magnetic flux created by the transmitting coil is what induces a current in the receiving coil, allowing for energy transfer between the two coils.
3. How is magnetic flux created in wireless power transfer?
Magnetic flux is created in wireless power transfer by passing an alternating current through the transmitting coil. This current creates a changing magnetic field, which in turn produces magnetic flux.
4. How does the distance between the transmitting and receiving coils affect the magnetic flux?
The distance between the transmitting and receiving coils can affect the strength of the magnetic flux. The further the distance, the weaker the magnetic flux will be, which can result in a decrease in the efficiency of energy transfer.
5. What are the advantages of using wireless power transfer over traditional wired methods?
Some advantages of wireless power transfer include convenience and flexibility, as it eliminates the need for physical wires and allows for charging without having to plug in devices. It also reduces the risk of electrical accidents and can be more efficient for certain applications.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
