How does ZF fixes Russell's paradox?
  • Thread starter quasar987
  • Tags
    Paradox
In summary: Let A be a set, and let P be a first-order predicate. We can write \{ x \in A \mid P(x) \} as follows:\{ x:x \in A \mid P(x) \}
quasar987
32
In naive set theory, Russell's paradox shows that the "set" [itex]S:=\{X:X \in X\}[/itex] satisfies the weird property [itex]S \in S[/itex] and [itex]S\notin S[/itex].
How does the set theory of Zermelo and Fraenkel get rid of this "paradox"? I.e., which axioms or theorem prohibit S above to be a set?
Thank you.
It's not that there's an axiom in ZF explicitly preventing Russell's Paradox, but rather ZF *doesn't* include the axiom of comprehension, which is the cause of all the trouble. Instead, it only allows for sets to be "built from" other sets, by union, by image under a function, by power set, and so on, and so on.
In particular, the expression [tex] \{ x \mid P(x) \} [/tex] for any old first-order predicate P is no longer necessarily a set, as it would be with comprehension.
Instead, we have the axiom of separation, which guarantees that [tex]\{ x \in A \mid P(x) \}[/tex] is a set, given any existing set A and predicate P.
So [tex]\{ x \in \mathbb{R} \mid x \notin x \}[/tex], [tex]\{ x \in 2^{\mathbb N} \mid x \notin x \}[/tex], and so on are sets, but none of these leads to contradictions (assuming ZF is consistent, of course!)
To put things differently... Cantor's set theory said [itex]S:=\{X:\mid X \in X\}[/itex], and Russell's paradox proves S is not a set. Thus contradiction.
In ZF, Russell's paradox still works to prove S is not a set. However, ZF does not (seem to) have a way to prove S is a set, and so there is no contradiction.
Incidentally, don't forget replacement which gives another ZF-legal form of set-builder notation:
[tex]\{ f(x) \mid x \in A \}[/tex]
The way in which all of this works is remarkedly similar to how formal logic (e.g. first-order, second-order, and so forth) avoids the liar's paradox.
Related to How does ZF fixes Russell's paradox?
1. What is ZF and what is Russell's paradox?
ZF stands for Zermelo-Fraenkel set theory, which is a foundational theory in mathematics. Russell's paradox is a famous paradox in set theory that was discovered by Bertrand Russell in 1901. It shows that the naive set theory, which assumes that any collection of objects can form a set, leads to a contradiction.
2. How does ZF fix Russell's paradox?
ZF fixes Russell's paradox by introducing the axiom of foundation, also known as the axiom of regularity. This axiom states that every non-empty set must contain an element that is disjoint from the set itself. This prevents the formation of sets that contain themselves, which was the main cause of the paradox.
3. Why is fixing Russell's paradox important?
Fixing Russell's paradox is important because it ensures that the foundation of mathematics is consistent and free from contradictions. Without addressing the paradox, the entire mathematical system could potentially collapse. ZF is widely accepted as the standard foundational theory in mathematics, and its solution to Russell's paradox is a crucial aspect of its validity.
4. Are there any criticisms of ZF's solution to Russell's paradox?
Yes, there are some criticisms of ZF's solution to Russell's paradox. One criticism is that the axiom of foundation is not intuitive and goes against the naive understanding of sets. Another criticism is that the axiom of foundation is not necessary to avoid Russell's paradox, and there are alternative solutions that do not require this axiom.
5. Is ZF the only theory that fixes Russell's paradox?
No, ZF is not the only theory that fixes Russell's paradox. There are other set theories, such as NBG (von Neumann-Bernays-Gödel set theory) and MK (Morse-Kelley set theory), that also address the paradox in different ways. However, ZF is the most widely accepted theory and is used as the foundation of most of modern mathematics.
18K
