How effective is torricellian vaccum?
  • Thread starter utkarsh5
In summary, the conversation discusses the effectiveness and limitations of a vacuum pump using torricellian vacuum. The person asks about the effectiveness and completeness of the vacuum, as well as the possibility of using it for a cathode ray tube. The expert responds by explaining that the vacuum is limited by the vapor pressure of the liquid used, and that all man-made vacuums will have some residual particles floating around. They also mention that a good vacuum pump will be needed for creating a vacuum suitable for electron shooting.
utkarsh5
23
i have designed a vacuum "pump" which uses torricellian vaccum.my "pump" just increases the size of torricellian vacuum by creating a low pressure area outside the barometer like apparatus.but that's not the question.my question is,how effective,or absolute is torricellian vaccum?is it complete vaccum,or does it still have some particles floating around?if i were to make a cathode ray tube like this,would it work?
Practically all man made vacuums will have at least some residual particles floating around. I don't know how effective your vacuum is though, sorry.
The pressure above the mercury surface will be the vapour pressure of mercury which is about 1.2μmm.Hg
The torricellian vacuum is limited by the vapor pressure of the liquid that you use to make the vacuum. Whatever liquid you use will have a specific vapor pressure at the temperature of the liquid.
When the vacuum finally reaches equilibrium, the pressure inside the cavity will equal the vapor pressure of the liquid. The particles in the partial vacuum will be molecules of vapor from the liquid.
what liquid should i use then?what liquid has lowest vapor pressure?
If you want to make a vacuum you can shoot electrons through you will probably need a decent vacuum pump.
FAQ: How effective is torricellian vaccum?
1. How does a torricellian vacuum work?
A torricellian vacuum is created by taking a long glass tube, filling it with mercury, and then inverting the tube into a dish of mercury. As the mercury falls down the tube, it creates a vacuum at the top of the tube. This creates a pressure difference between the bottom and the top, resulting in a torricellian vacuum.
2. Is a torricellian vacuum completely empty?
No, a torricellian vacuum is not completely empty. While it does have a very low pressure, it is not a perfect vacuum. There are still trace amounts of gases and particles present in the vacuum.
3. How is a torricellian vacuum used in experiments?
A torricellian vacuum is commonly used in experiments to demonstrate the principles of gas pressure. It is also used in barometers and vacuum pumps.
4. What are the limitations of a torricellian vacuum?
The main limitation of a torricellian vacuum is that it cannot create a perfect vacuum. It also has a limited amount of suction power, making it less effective in certain experiments or applications.
5. Can a torricellian vacuum be dangerous?
While a torricellian vacuum is not inherently dangerous, it can be if proper precautions are not taken. The mercury used to create the vacuum can be toxic if ingested or inhaled. Additionally, the glass tube can break and cause injury. It is important to handle a torricellian vacuum with caution and follow proper safety protocols.
