How efficient is a microwave oven
In summary, the debate over microwave oven efficiency is ongoing and inconclusive. There is some evidence to suggest that reciprocity failure (the rule of thumb that when you double the quantity you must double the time to cook) might not always be accurate. Some argue that efficiency also depends on what's in the oven (i.e. a more polar molecule will rotate better than a less polar molecule), while others maintain that doubling the quantity still results in overcooking.
Homer D.
This site was at the top of the Google results for "How efficient is a microwave oven"
I can't restart the old discussion, so I'll start a new thread.
Previous posters came up with numbers from 99% to 46%.
The Wikipedia page offers only this:
"A microwave oven converts only part of its electrical input into microwave energy. A typical consumer microwave oven consumes 1100 W of electricity in producing 700 W of microwave power, an efficiency of 64%. The other 400 W are dissipated as heat, mostly in the magnetron tube. Additional power is used to operate the lamps, AC power transformer, magnetron cooling fan, food turntable motor and the control circuits. Such wasted heat, along with heat from the product being microwaved, is exhausted as warm air through cooling vents."
Also of course, some energy exits into the room through the door's grid glass. It's not a perfect barrier, but a convenient compromise. Commercial food service units have no glass.
A member "cdotter" offered the observation "Wouldn't the efficiency depend on the type of food? A more polar molecule will rotate better than a less polar molecule."
I agree that efficiency also depends on what's in the oven. Presumably if running it empty the oven would still consume house current and yet nothing's on the turntable to get hot.
I'm wondering if there is any data about this. 99% 64% 46% is such a wide range.
Science news on Phys.org
I think based on your analysis, a wide range is appropriate, no?
One could relatively easily test this by timing how long it takes to boil some water though...
64% looks reasonable for an efficiency electric -> microwaves (depends on the model, too, of course). The part of the microwaves which gets absorbed by the food depends on the type of food, its quantity and distribution and the microwave, so the total efficiency will be a bit lower and variable.
The efficiency quoted (64%) refers to the conversion of electric power to microwaves.
How the microwaves are used is a different story.
What actually puzzles me most is the contention that when you double the quantity you must double the time to cook. If a given sausage is cooked in one minute and you want two, it seems they are done (split from steam) before the full two minutes are up.
termed "reciprocity failure"
That rule of thumb could apply for large items but the poor matching of the energy into some small items could compromise the actual Mains to RF efficiency.
Related to How efficient is a microwave oven
1. How does a microwave oven work?
A microwave oven uses electromagnetic radiation in the form of microwaves to heat and cook food. These microwaves cause the water molecules in food to vibrate, creating heat that cooks the food.
2. How efficient is a microwave oven compared to other cooking methods?
A microwave oven is generally more efficient than traditional cooking methods such as stovetop or oven cooking. This is because it uses less energy and cooks food faster, resulting in less energy waste and lower electricity bills.
3. Does the size of a microwave oven affect its efficiency?
Generally, the size of a microwave oven does not significantly affect its efficiency. However, larger microwaves may use slightly more energy to run, but this is usually offset by their ability to cook larger quantities of food at once.
4. Can a microwave oven overheat or cause food to become too hot?
Microwave ovens are designed with safety features that prevent them from overheating or causing food to become too hot. They also have timers and sensors that automatically shut off the microwave when the food is cooked, preventing it from becoming overcooked.
5. Is it safe to use a microwave oven to heat or cook all types of food?
Microwave ovens are generally safe to use for most types of food. However, it is important to follow the manufacturer's instructions and use microwave-safe containers to prevent accidents or damage to the oven. Some foods, such as eggs in their shells or sealed containers, should not be cooked in a microwave as they can explode.
  • Optics
9K
29K
  • Optics
34K
  • Thermodynamics
12K
