riggi91
- 4
A 4-kg rock is tied to the end of a string and twirled overhead, 1.6 m above the ground, in a 1.1-m radius, horizontal circle. The string is known to break if its tension reaches a value of 514 N. The rock it rotated faster and faster until the string breaks. How far away from its location when the string breaks will the rock hit the ground? Your answer should be given in meters, to the nearest centimeter.
F=mv^2/r
y=-.5gt^2
x=vxo(t)
What I did was I found V first by doing sqrt(f*r/m)
Then I found t by doing sqrt(2y/g)
then I multiplied vt.
I've tried this three times and I keep getting this answer wrong. On my last attempts I've been getting between 6.9m and 7.1m based on the configuration of the numbers as they change slightly each time I attempt the problem.
What am I doing wrong?
Thanks
