How far away is the Oort Cloud?
In summary, the Oort comet cloud is theorized to exist roughly from 2,000-5,000 AU to 50,000 AU or possibly up to 100,000-200,000 AU, with estimates putting its size at about 50,000 AU. It is possible that some comets in the Oort cloud may have originated from outside our solar system, orbiting at distances as far as 300,000 AU. This cloud could potentially be shared by multiple stars in a system and may have an hourglass shape with a lobe around each star and a waist at the gravitational midpoint. Observational data on the Oort cloud is limited, with numerical simulations providing the best estimates of its size and composition
cph
43
How far away is the Oort comet cloud? 1000 AU or 10,000 AU? c=10^10 cm/sec. for 10^8 sec/yr., gives 10^18 cm/lyr. Approximately then, is 1000 AU ~ .01 lyr? And 10,000 AU ~ .1 lyr? Would this be large enough to contain a multi-stellar system, since stars form in multiple? Hence a common Oort cloud for a center of mass for such system?
Astronomy news on Phys.org
According to wikipedia the Oort cloud is theorized to exist roughly from 2,000-5,000 AU to 50,000 AU, or 1 light year from the sun. Some estimates put the outer edge at up to 100,000 - 200,000 AU. (1.58-3.16 ly)
Multi-star systems have been observed with the stars separated by anywhere between a few AU up to hundreds or thousands of AU if not more, so the Oort cloud can easily be shared by two stars if it actually does form. Depending on the configuration of the system I could see having more than one star making conditions too unstable for the cloud to form.
I have seen several posts on the web that put the Oort cloud at anything up to 3 LY away.
What no one seems to consider is that the gravitational mid point between the sun and Alpha centaury is at 1.5LY from our sun. This means that any object in the Oort that is orbiting further out than this will be either be captured by Alpha Centaury or it must be orbiting both stars in a figure of eight orbit and the Oort cloud would have an hourglass shape with a lobe around each star and the waist of the hourglass at the gravitational mid point.
I have made a request for feedback on this point in a seaprate post, any input would be welcomed.
The best guess at the Oort cloud size is about 50,000 AU. The alpha centauri system is about 270,000 AU distant. It has probably been disrupted by near approaches from wandering stars, brown dwarfs or even ejection of planets from the primordial solar system. Such events number among those conjectured to explain the late heavy bombardment period.
Nobody knows for sure because it is extremely hard to obtain observational data on this. The best what can be done actually is to resort to numerical simulations. From these it became clear that one can not set a precise boundary to the Oort cloud because the number of comets per unit volume decrease with the distance from the sun according to some law. However, from these simulations one can guess that most of the comets is contained in a radius of 30-50.000 AU. But theere is no cut-off and few comets may go much further, fading away with some having aphelions extending as far as 300.000 AU. That is about alpha centauri's distance and in fact it is speculated that several of our Oort cloud comets might have extra solar origin. However, these comets orbiting further away from the sun might be just those more relevant for planetary impacts (and therefore for the existence of life) since they are those which are most perturbed by stellar encounters and galactic tides.
For further reading see also:
http://arxiv.org/abs/1110.5114
http://arxiv.org/abs/1108.1570
http://arxiv.org/abs/1009.5264
http://arxiv.org/abs/astro-ph/0512256
Related to How far away is the Oort Cloud?
1. What is the Oort Cloud?
The Oort Cloud is a theoretical spherical region located at the outermost edge of our solar system, believed to be the origin of long-period comets.
2. How far away is the Oort Cloud from Earth?
The Oort Cloud is estimated to be between 2,000 and 200,000 astronomical units (AU) away from Earth. To put this into perspective, 1 AU is the distance between the Earth and the Sun, which is approximately 93 million miles.
3. How was the Oort Cloud discovered?
The Oort Cloud was first proposed by Dutch astronomer Jan Oort in 1950, based on observations of the orbits of comets and their long-distance trajectories in the outer solar system.
4. What is the significance of the Oort Cloud?
The Oort Cloud is believed to be the source of long-period comets, which can provide valuable information about the early formation of our solar system. It also helps explain the origin of comets and their unique orbits.
5. Can the Oort Cloud be observed or studied?
Due to its immense distance from Earth, the Oort Cloud cannot be directly observed or studied. Scientists rely on indirect evidence, such as the orbits of comets, to learn more about this distant region of our solar system.
  • Astronomy and Astrophysics
