How Far Can A Person See?
The discussion centers on calculating how far a person can see from the observation deck of the Burj Khalifa, which is 1450 feet high. The Pythagorean Theorem is applied to determine the distance, with the radius of the Earth set at 3960 miles. A user suggests using the equation s^2 + r^2 = [r + (d/m)]^2 to solve for the distance s. It is recommended to solve the equation symbolically before inserting numerical values for accuracy. The thread concludes abruptly due to the original poster being banned for creating multiple accounts.
felizgu
How far can a person see standing on the observation deck?
Pythygorean Theorem
The tallest building in the world is Burj Khalifa in Dubai, United Arab Emirates, at 2717 feet and 160 floors.The observation deck is 1450 feet above ground level. How far can a person standing on the observation deck see (with the aid of a telescope)? Use 3960 miles for the radius of Earth.
Let me see. I know that the Pythygorean Theorem is needed.
Let s = how far a person can see.
Let d = height of observation deck.
Let r = radius of Earth
Let m = number of feet in a mile
I think the correct expression of the Pythagorean Theorem for this problem is the following:
s^2 + r^2 = [ r + (d/m)]^2
I will now replace the letters with the value for each. I need to solve for s.
(s)^2 + (3690)^2 = [3960 + (1450/5280)]^2
Is this the correct set up?
It looks correct.
I would recommend solving the initial equation symbolically first and only then insert the numbers to calculate the actual value.
Likes felizgu
Thread closed due to OP being banned for creating multiple accounts.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
