How Far Do the Blocks Slide After Spring Release?
In summary, the problem involves two blocks, M1 and M2, resting motionless on a surface of friction coefficient μk. A powerful spring, compressed by amount x, is in a cavity inside of the blocks and held together by a hook. When the hook is released, the blocks are flung apart and the question is how far apart will they be after they stop sliding. Using the work energy theorem, it can be determined that the displacement d is equal to (1/2kx^2 - ukmgx)/ukmg, where x is the original compression of the spring, k is the force constant of the spring, and m and g are the masses of the blocks and gravitational acceleration, respectively.
vande060
186
Two blocks M1 and M2 rest motionless on
spring of force constant k, compressed by
amount x, is in a cavity inside of them. A
hook holds them together. When the hook is
released, they are flung apart. How far apart
will they be after they stop sliding?
http://s861.photobucket.com/albums/ab174/alkaline262/?action=view&current=book2question2.jpg
W = 1/2m1v1^2 - 1/2m1v1^2
mew = u
okay here we go(maybe)
the potential function for a spring -V = 1/2kx^2
potential function for kinetic friction = ukmgx
not sure about the works above, and if i did the 100% right
work energy theorem 1/2m1v1^2 + 1/2m2v2^2 = 1/2kx^2 - ukmgx
i don't suppose i could just set v1 = v2 = 0 :biggrin: and solve the quadratic for x
No, because that is a trivial solution.
You are thinking along the right lines, but you don't have to think about the velocities of the blocks at all. You know the P.E. of the spring is the total energy of the system before the hook is released. Then after the blocks come to rest the total energy is 0. What happened to all that energy? (Hint, work done by friction, which is proportional to distance moved ;) )
I don't really understand what you are saying here. could you rephrase it please? I am thinking all of that energy is lost during the displacement, where friction is causing loss of energy by heat and noise
so at the risk of reinventing the wheel: kx^2 - ukmgD = 0
d=displacement
i have never really been sure what x represents in the spring function, i don't know if it is the same as displacement
Think about it a little harder, you have the general equation right but there are some coefficients and simplifications you can make. (Specifically a factor of 1/2 in front of the PE? and D=x+d, and d is what you want.)
okay, i really understand the difference between d and x now. Also, I believe that the coefficent of 1/2 only belongs before the PE of the the spring, correct me if i am wrong but:
1/2kx^2 -ukmg(x+d) = 0
1/2kx^2 -ukmgx - ukmgd = 0
1/2kx^2 -ukmgx = ukmgd
(1/2kx^2 -ukmgx)/ukmg = d
i would have to how much the spring was originally compressed by, along with masses to solve this any further i think
FAQ: How Far Do the Blocks Slide After Spring Release?
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a scalar quantity that depends on the mass and velocity of an object.
How is kinetic energy calculated?
Kinetic energy can be calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
What are some real-life examples of kinetic energy?
Some examples of kinetic energy in everyday life include a moving car, a ball being thrown, or a person running.
How does kinetic energy relate to potential energy?
Kinetic energy and potential energy are two forms of energy that are related to each other. Potential energy is the energy an object has due to its position or state, while kinetic energy is the energy an object has due to its motion. The two types of energy can be converted into each other.
How does friction affect kinetic energy?
Friction is a force that opposes motion and can decrease an object's kinetic energy. When an object moves against a surface with friction, some of its energy is converted into heat, reducing its kinetic energy.
