How far do vibrations from a vehicle emanate?Doppler effect?
In summary, the conversation discusses the sensitivity of snakes to vibrations in the ground and whether the vibrations from a vehicle can cause them to flee or if they were already moving. The main question is at what speed a 4-cylinder gasoline engine would need to travel on asphalt to stay ahead of the vibrational waves it creates. The conversation also touches on the speed of sound in different mediums and the difference between surface waves and compression waves. The conclusion is that a snake would be able to sense a vehicle approaching at the same distance regardless of its speed.
sistruguru
So I have a strange question. I study snakes, which are of course sensitive to vibrations in the ground. A common technique for finding snakes is to drive roads at night. A constant debate that comes up among herpetologists is whether or not the vibrations of the vehicle are causing the snakes to flee, or, if the snakes were already moving, and you just happen to find the animal when it is moving.
So my questions, and I realize this will apply on a specific basis (probably every single vehicle is unique). #1, Is there any general knowledge out there about shock waves/ vibrations from an idle engine (let's say a 4 cylinder gasoline engine) on asphalt.
#2 - I'm not sure if the doppler effect only applies to sound waves, and if so, I'm not sure what the equivalent is, but in my mind, I'm picturing a speed boat, which leaves a wake behind it, and of course immediately in front of the boat, the water has yet to be disturbed. So this seems like an equivalent to the doppler effect, but with waves (literal, liquid waves). Would there not be something similar with a vehicle driving down the road?
At idle, vibrations should radiate in 360 degrees from the vehicle. As it moves forward, the vibrations emanating from the front should get more compressed as the vehicle moving forward is covering the ground that those waves are propagating from. I know sound moves faster in water than air. But what about water vs land? For sake of simplicity, I'm suggesting a substrate made up entirely of asphalt. I'd assume it would be slower, because there are still plenty of air pockets in asphalt. But asphalt is also less flexible than water...
So the last question, and the main one, #3 - at what speed would a 4-cylinder gasoline engine have to travel at, on asphalt, to stay "ahead" of the vibrational waves it is creating?
I appreciate any insight, or suggested reading anyone could point me to. I know whatever answer comes out of this will not be 100% precise as there are too many variables and considerations (the type of asphalt, the distance of the engine from the ground, the size of the tires, how well balanced/ old the engine is, and plenty of others) - I'm just looking for an approximation, something with a ~75-80% certainty.
Thank you,
-Kevin
You need to ask the same questions for two cases. Sound emitted in air by the vehicle. Sound in the road and the ground excited by contact with the tires. So the answer to #3 is the speed of sound. But the speed of sound in air is not the same as in the ground. Suffice it to say that cars can't drive faster than the sound barrier in either case.Your question reminds me of my youth living near train tracks. By putting one's ear to the rail, trains could be heard approaching from many miles away.
Ok, but of course snakes are deaf and don't easily pick up sound waves - they do pick up vibrations in the ground. I figured the physical vibrations of the ground would be greatly slower than the speed of sound. Yes, that's basically the idea, putting your ear to the ground, at what distance can a vehicle be noticed. Hmmm... maybe I could just do a simple curiosity experiment. But ultimately, yeah, I'm pretty sure you can feel the vehicle approaching from quite a distance. I would imagine a train would be easier to sense because of the steel or iron in the rails (much more dense) and the fact that the train is vastly heavier than 1,500 lbs.
[PLAIN]https://en.wikipedia.org/wiki/Seismic_wave said:
2[/PLAIN] to 8 km/s in the Earth's crust,
Not greatly slower, 17895 mph.
lol. Nice, I like having straight up values. Ok. A friend just started discussing the topic with me. In my boat analogy, I was mentioning the fact that if you're on a raft, you don't really sense an approaching speedboat (yes you can hear it, but let's pretend you're deaf). It wouldn't be until after the boat passes, that you feel the waves generated by the boat. Even if underwater, sure you'd be able to hear the sound of the engine (the sound wave), but you wouldn't be able to "feel" it, until the boat passed. He mentioned that that situation had to do with a surface wave vs a compression wave vs a sound wave. I guess these are the sort of waves I was thinking of. But he was saying that on land you wouldn't produce a surface wave.
Regardless, thanks for the conversation. I think I have my answer - no matter how fast, or how slow, a snake would be able to sense a vehicle approaching at essentially the same distance, whether the vehicle was driving at 15 mph or 70 mph. Thanks!
For some highly sensitive physics experiments such as LIGO and LHC, it's very important that as much as possible background noise can be eliminated.
Sure, the Doppler effect will apply. But as stated above, the source needs to be moving awfully fast to make much difference.
FAQ: How far do vibrations from a vehicle emanate?Doppler effect?
What is the source of vibrations from a vehicle?
The primary source of vibrations from a vehicle is the engine, which produces mechanical energy that is transferred to the rest of the vehicle through the drivetrain and wheels.
How far can vibrations from a vehicle travel?
The distance that vibrations from a vehicle can travel depends on a variety of factors, such as the size and weight of the vehicle, the type of surface it is traveling on, and the intensity of the vibrations. In general, vibrations from a vehicle can travel several meters or more.
How do vibrations from a vehicle affect nearby objects?
Vibrations from a vehicle can affect nearby objects in a few different ways. For example, they can cause objects to vibrate or shake, which may be noticeable in nearby buildings or structures. They can also cause noise, which can be heard by nearby individuals.
Is there a difference in the distance that vibrations can travel on different types of surfaces?
Yes, the type of surface can have a significant impact on how far vibrations from a vehicle can travel. For example, vibrations can travel further on hard surfaces like concrete compared to softer surfaces like grass or dirt.
How does the Doppler effect play a role in the distance that vibrations from a vehicle travel?
The Doppler effect refers to the change in frequency of a wave as its source moves closer or further away from an observer. In the case of vibrations from a vehicle, the Doppler effect can cause the frequency and intensity of the vibrations to change as the vehicle moves, which can affect how far they travel and how they are perceived by nearby objects or individuals.
