How Far Does a Bookworm Travel Through a 3-Volume Set?
  • MHB
  • Thread starter soroban
  • Tags
    Challenge
In summary, the Bookworm's journey can be calculated by dividing the total number of books read by the average number of books read per day. The 3-Volume Challenge is a reading challenge where the Bookworm must read three volumes of books in a specific order, with each volume containing 10-15 books. The average number of books read per day for the Bookworm can be determined by dividing the total number of books read by the number of days it took to complete the journey. It is possible for the Bookworm's journey to be completed in less than 3 volumes by reading more books per day or choosing volumes with a higher number of books.
soroban
194
There is a 3-volume set of books
$\quad$on a bookshelf in the usual manner.
Each volume has two covers, each $\frac{1}{4}$ inch thick,
$\quad$and the printed portion is $1$ inch thick.
A bookworm starts at the first page of Volume 1
$\quad$and eats his way to the last page of Volume 3.
How far does the bookworm travel?
Before you ask: we want his shortest distance.)
Hello, Evgeny.Makarov!
Absolutely correct!
If you have not seen the problem before,
. . good work!
Even if you had seen this problem before,
. . thank you for participating.
FAQ: How Far Does a Bookworm Travel Through a 3-Volume Set?
How do you calculate the Bookworm's journey?
The Bookworm's journey can be calculated by determining the total number of books read by the Bookworm, and then dividing that number by the average number of books read per day. This will give you the total number of days it took the Bookworm to complete the journey.
What is the 3-Volume Challenge?
The 3-Volume Challenge is a reading challenge where the Bookworm must read three volumes of books in a specific order, with each volume containing a set number of books. The goal is to complete the entire journey in the shortest amount of time possible.
How many books are in each volume of the challenge?
The number of books in each volume of the challenge may vary depending on the specific challenge. However, typically each volume contains 10-15 books.
How do you determine the average number of books read per day for the Bookworm?
The average number of books read per day for the Bookworm can be calculated by dividing the total number of books read by the number of days it took to complete the journey. This will give you the average number of books read per day.
Can the Bookworm's journey be completed in less than 3 volumes?
Yes, it is possible for the Bookworm's journey to be completed in less than 3 volumes. This would require the Bookworm to read more books per day or to read volumes with a higher number of books.
10K
14K
16K
12K
