RyanJF
- 16
"A rock is thrown horizontally at 25 m/s from a 15-m roof. How far does the rock travel away from the building before hitting the ground?"
In the X-component:
Xx = ?
Vox = 25 m/s
T = ?
Vx = 0
In the Y-component:
Xy = 15m
Ag = 9.8
T = ?
Vy = 0
Kinematics equations
First thing I did was picked an appropriate equation that would allow me to solve for Xx. The equation that I selected was:
Xx = 1/2 (Vox + Vx) T
In order to solve for Xx, it would first be necessary for me to acquire a value for T. I solved for T by doing:
T = sqrt(2x/a)
Plugged in with the correct numbers, this turned out to:
T = sqrt(2*15/9.8)
Therefore
T = 1.75 sec
I would assume that I'm using the vertical value for distance (15 m), given that that downwards motion, in conjunction with acceleration due to gravity, shall determine how far the projected rock will travel.
My final answer ended up being:
Xx = 21.875 m
Although I think the correct answer should be closer to around 43.74 m. This was just an example problem given to the class, but I'm not sure how I'm supposed to arrive at the presented conclusion. I'm quite confident that I correctly solved for T, and I thought I used the right equation for displacement, but there's clearly something that I did wrong.
Can somebody please explain this to me?
